查看: 14368|回复: 3
[CSR8系列] CSR8670 在source_usb.c里有一个问题,有谁能告诉我
签到总天数:1433天
签到总奖励:16581金币
发表于 2018-12-19 16:27:47 | 显示全部楼层 |阅读模式
  1. void usb_send_hid_answer(void)
  2. {
  3.     if (theSource->ps_config->usb_config.usb_hid_keyboard_interface)
  4.     {
  5.         /* send ALT+PGUP over USB */
  6.        UsbDeviceClassSendEvent(USB_DEVICE_CLASS_EVENT_HID_KEYBOARD_ALT_PGUP);
  7.     }
  8. }
复制代码
USB_DEVICE_CLASS_EVENT_HID_KEYBOARD_ALT_PGUP找不到HID相关描述
哪个大神,能告诉我一下,谢谢啦!
签到总天数:833天
签到总奖励:24022金币
发表于 2018-12-19 21:39:21 | 显示全部楼层
  1. /*!
  2.     Possible values that can be passed into the UsbDeviceClassSendEvent API. Events are only valid if the correct device class has been enumerated.
  3. */
  4. typedef enum
  5. {
  6.     /*! Send a HID consumer play/pause event over USB */
  7.     USB_DEVICE_CLASS_EVENT_HID_CONSUMER_TRANSPORT_PLAY_PAUSE,
  8.     /*! Send a HID consumer stop event over USB */
  9.     USB_DEVICE_CLASS_EVENT_HID_CONSUMER_TRANSPORT_STOP,
  10.     /*! Send a HID consumer next track event over USB */
  11.     USB_DEVICE_CLASS_EVENT_HID_CONSUMER_TRANSPORT_NEXT_TRACK,
  12.     /*! Send a HID consumer previous track event over USB */
  13.     USB_DEVICE_CLASS_EVENT_HID_CONSUMER_TRANSPORT_PREVIOUS_TRACK,
  14.     /*! Send a HID consumer play event over USB */
  15.     USB_DEVICE_CLASS_EVENT_HID_CONSUMER_TRANSPORT_PLAY,
  16.     /*! Send a HID consumer pause event over USB */
  17.     USB_DEVICE_CLASS_EVENT_HID_CONSUMER_TRANSPORT_PAUSE,
  18.     /*! Send a HID consumer Fast Forward ON event over USB */
  19.     USB_DEVICE_CLASS_EVENT_HID_CONSUMER_TRANSPORT_FFWD_ON,
  20.     /*! Send a HID consumer Fast Forward OFF event over USB */
  21.     USB_DEVICE_CLASS_EVENT_HID_CONSUMER_TRANSPORT_FFWD_OFF,
  22.     /*! Send a HID consumer Rewind ON event over USB */
  23.     USB_DEVICE_CLASS_EVENT_HID_CONSUMER_TRANSPORT_REW_ON,
  24.     /*! Send a HID consumer Rewind OFF event over USB */
  25.     USB_DEVICE_CLASS_EVENT_HID_CONSUMER_TRANSPORT_REW_OFF,
  26.     /*! Send a HID consumer Volume Up event over USB */
  27.     USB_DEVICE_CLASS_EVENT_HID_CONSUMER_TRANSPORT_VOL_UP,
  28.     /*! Send a HID consumer Volume Down event over USB */
  29.     USB_DEVICE_CLASS_EVENT_HID_CONSUMER_TRANSPORT_VOL_DOWN,
  30.     /*! Send a HID consumer Mute event over USB */
  31.     USB_DEVICE_CLASS_EVENT_HID_CONSUMER_TRANSPORT_MUTE,
  32.     /*! Send a HID keyboard ALT+PageUp event over USB */
  33.     USB_DEVICE_CLASS_EVENT_HID_KEYBOARD_ALT_PGUP,
  34.     /*! Send a HID keyboard ALT+PageDown event over USB */
  35.     USB_DEVICE_CLASS_EVENT_HID_KEYBOARD_ALT_PGDN,
  36.     /*! Send a HID keyboard ALT+End event over USB */
  37.     USB_DEVICE_CLASS_EVENT_HID_KEYBOARD_ALT_END
  38. } usb_device_class_event;
复制代码
签到总天数:1433天
签到总奖励:16581金币
 楼主| 发表于 2018-12-20 16:19:22 | 显示全部楼层
楼上,你好!这个表放在哪个文件下的,我没有找到
签到总天数:1433天
签到总奖励:16581金币
 楼主| 发表于 2018-12-20 16:21:44 | 显示全部楼层
源代码的source_usb.c里HID描述,里面只有(Consumer Devices)的,哪个大神,能不能给一份里面有(Telephony Devices)的描述?
GMT+8, 2026-11-12 21:40 , Processed in 0.021237 second(s), 12 queries , Gzip On, Redis On.
