查看: 5301|回复: 6
[QCC5系列] MDE不能输出打印,请问是什么问题引起的?如何解决?
签到总天数:66天
签到总奖励:421金币
发表于 2020-5-28 19:11:42 | 显示全部楼层 |阅读模式
device = qcc512x_qcc302x-lab
chip = qcc512x_qcc302x-r02-v0
Traceback (most recent call last):
  File "C:/qtil/ADK_QCC512X_QCC302X_WIN_6.4.2.26/extensions/pydbg_tabs/py/pydbg_tab.py", line 449, in <module>
    PydbgFrontEnd.main_wrapper()
  File "C:\Public\tmp_pkg_pydbg6yqoro\pkg_pydbg_aura_d01_ext_win32_win64_1911181640\progfiles\apps\fw\tools\pylib\csr\front_end\base_front_end.py", line 262, in main_wrapper
  File "C:\Public\tmp_pkg_pydbg6yqoro\pkg_pydbg_aura_d01_ext_win32_win64_1911181640\progfiles\apps\fw\tools\pylib\csr\wheels\py2_compatibility.py", line 22, in _exec_cmd
  File "C:/qtil/ADK_QCC512X_QCC302X_WIN_6.4.2.26/extensions/pydbg_tabs/py/scripts/fw_live_log.py", line 16, in <module>
    apps1.fw.env.load=True # Force the firmware environment to load first
  File "C:\Public\tmp_pkg_pydbg6yqoro\pkg_pydbg_aura_d01_ext_win32_win64_1911181640\progfiles\apps\fw\tools\pylib\csr\wheels\bitsandbobs.py", line 962, in __setattr__
  File "C:\Public\tmp_pkg_pydbg6yqoro\pkg_pydbg_aura_d01_ext_win32_win64_1911181640\progfiles\apps\fw\tools\pylib\csr\wheels\bitsandbobs.py", line 927, in __create_on_demand
  File "C:\Public\tmp_pkg_pydbg6yqoro\pkg_pydbg_aura_d01_ext_win32_win64_1911181640\progfiles\apps\fw\tools\pylib\csr\dev\env\standalone_env.py", line 190, in __init__
  File "C:\Public\tmp_pkg_pydbg6yqoro\pkg_pydbg_aura_d01_ext_win32_win64_1911181640\progfiles\apps\fw\tools\pylib\csr\dev\fw\meta\i_firmware_build_info.py", line 690, in elf_slt
  File "C:\Public\tmp_pkg_pydbg6yqoro\pkg_pydbg_aura_d01_ext_win32_win64_1911181640\progfiles\apps\fw\tools\pylib\csr\dev\fw\meta\i_firmware_build_info.py", line 428, in elf_code
  File "C:\Public\tmp_pkg_pydbg6yqoro\pkg_pydbg_aura_d01_ext_win32_win64_1911181640\progfiles\apps\fw\tools\pylib\csr\dev\fw\meta\i_firmware_build_info.py", line 435, in elf_reader
  File "C:\Public\tmp_pkg_pydbg6yqoro\pkg_pydbg_aura_d01_ext_win32_win64_1911181640\progfiles\apps\fw\tools\pylib\csr\dev\fw\meta\i_firmware_build_info.py", line 409, in elf_file
  File "C:\Public\tmp_pkg_pydbg6yqoro\pkg_pydbg_aura_d01_ext_win32_win64_1911181640\progfiles\apps\fw\tools\pylib\csr\dev\fw\meta\i_firmware_build_info.py", line 398, in _cache_elf_if_necessary
  File "C:\Public\tmp_pkg_pydbg6yqoro\pkg_pydbg_aura_d01_ext_win32_win64_1911181640\progfiles\apps\fw\tools\pylib\csr\wheels\bitsandbobs.py", line 1075, in path_is_windows_remote_mount
UnicodeDecodeError: 'ascii' codec can't decode byte 0xbb in position 0: ordinal not in range(128)
签到总天数:765天
签到总奖励:7275金币
发表于 2020-5-28 20:47:38 | 显示全部楼层
把系统换成英文的,试试
签到总天数:1170天
签到总奖励:45846金币
发表于 2020-5-29 00:48:40 | 显示全部楼层
找到你错误日志里面的fw_live_log.py,在第一个import下面加上这三行import sys
reload(sys)
sys.setdefaultencoding('gbk')
点评
加单直接明了,不巴拉巴拉一堆的好多了  发表于 2020-6-23 15:31
回复 支持 2 反对 0
签到总天数:66天
签到总奖励:421金币
 楼主| 发表于 2020-5-30 11:12:54 | 显示全部楼层
reload(sys)
sys.setdefa ...
解决问题,多谢指导。
签到总天数:97天
签到总奖励:1537金币
发表于 2020-6-2 16:00:11 | 显示全部楼层
reload(sys)
sys.setdefa ...
厉害
连续签到天数:3天
签到总天数:77天
签到总奖励:609金币
发表于 2020-8-4 14:20:26 | 显示全部楼层
reload(sys)
sys.setdefa ...
牛逼啊
GMT+8, 2024-4-27 02:27 , Processed in 0.165580 second(s), 20 queries , Gzip On, MemCached On.
