问题更新:qcc5126 设备连接苹果ios的时候,访问通讯录时弹出用户授权访问通讯录的提示是车载设备
提示如下:
“您的车可能会访问通讯录。。。。”
有没有可能,把“您的车”改成“你的XX”,XX可以自定义,或者就是通用的名称,比如“设备”也可以。
那位大佬知道的话,不吝赐教啊
分割线--------------------------------------------------------------------------------------------------------------------------
qcc5126 设备连接苹果ios的时候,需要访问通讯录但是没有弹出用户授权访问通讯录的提示
用其他的设备在配对一开始会弹出提示如图
通过抓取的log确定sdp中已经注册了pbap协议,有大佬知道是怎么回事吗?
Qq群的大佬“踏雪无痕”指点改class_of_device void sinkInitConfigureDeviceClass(void) { //uint32 device_class = sinkInitGetDeviceClassConfig(); ConnectionWriteClassOfDevice(0x00240408); }
下面对CoD做简要的说明
Assigned Numbers for Baseband
Assigned numbers for Baseband identifies the Inquiry Access codes and Class of Device/Service (CoD) fields.
基带分配编号
为基带分配的编号标识了查询访问代码和设备/服务类别(CoD)字段。
The General- and Device-specific Inquiry Access Codes (DIACs)
The Inquiry Access Code (IAC) is the first level of filtering for finding Bluetooth® devices and services. The main purpose of defining multiple IACs is to limit the number of responses when scanning devices within range.
通用和特定于设备的查询访问代码(DIAC)
查询访问代码(IAC)是用于查找Bluetooth®设备和服务的第一级过滤。 定义多个IAC的主要目的是限制扫描范围内的设备时的响应数量。
C:\Users\hjw\AppData\Local\YNote\data\weixinobU7VjixR36LtX24EbczQm-GnRPY\efddc393d4dd4a71b97a50dbd6c9ba8b\clipboard.png
Table 1: Inquiry Access Codes
The Limited Inquiry Access Code (LIAC) is to be used only for limited periods in scenarios where both sides have been explicitly caused to enter this state, usually by user action. For further explanation of the use of the LIAC, please refer to the Generic Access Profile.
In contrast, it is allowed to continuously scan for the General Inquiry Access Code (GIAC) and respond whenever inquired.
限制查询访问代码(LIAC)仅在有限的时间段内使用,在这种情况下,通常是由于用户操作,导致双方显式进入此状态。 有关LIAC用法的进一步说明,请参阅通用访问配置文件。
相反,允许连续扫描通用查询访问代码(GIAC),并在每次查询时做出响应。
The Class of Device/Service field
The Class of Device/Service (CoD) field has a variable format. The format is indicated using the “Format Type field” within the CoD. The length of the Format Type field is variable and ends with two bits different from “11.” The version field starts at the least significant bit of the CoD and may extend upward.
In the “format #1” of the CoD (Format Type field = 00), 11 bits are assigned as a bit-mask (multiple bits can be set), each bit corresponding to a high-level generic category of service class. Currently, seven categories are defined. These are primarily of a “public service” nature. The remaining 11 bits are used to indicate device type category and other device-specific characteristics.Any reserved but otherwise unassigned bits, such as in the Major Service Class field, should be set to zero.
设备/服务类别字段
设备/服务类别(CoD)字段具有可变格式。 使用CoD中的“格式类型字段”指示格式。 格式类型字段的长度是可变的,并且以不同于“ 11”的两位结尾。 版本字段从CoD的最低有效位开始,并且可以向上扩展。
在CoD的“格式#1”中(格式类型字段= 00),将11位分配为位掩码(可以设置多个位),每个位对应于服务类的高级通用类别。 当前,定义了七个类别。 这些主要是“公共服务”性质的。 其余的11位用于指示设备类型类别和其他设备特定的特性。任何保留但未分配的位(例如在“主要服务类”字段中)应设置为零。
ps:CoD 总共包括24位,高11位是 主要服务类,
Major Service Classes
The Major and Minor Service classes define the general families of devices with which Bluetooth SIG members want their applications to be associated. No assumptions about the specific functionality or characteristics of any application should be based solely on its inclusion within a
主要服务等级
主要和次要服务类定义了与蓝牙SIG成员希望其应用程序关联的设备的一般系列。 任何应用程序的特定功能或特性的假设都不应仅基于其包含在主要设备或次要设备类中。
ps:#define AUDIO_MAJOR_SERV_CLASS 0x200000
对应主要服务类是 21 Audio headset
#define RENDER_MAJOR_SERV_CLASS 0x040000
18 Rendering(printing,Speakers)
C:\Users\hjw\AppData\Local\YNote\data\weixinobU7VjixR36LtX24EbczQm-GnRPY\4eb081d44be74a598ac0234a035d0789\clipboard.png
Major Device Classes
The Major Device Class segment is the highest level of granularity for defining a Bluetooth device. A device’s main function determines its Major Class assignment. There are 32 major classes. The assignment of this Major Class field is defined in the table.
主要设备类别
“主要设备类别”部分是用于定义蓝牙设备的最高粒度级别。 设备的主要功能决定了其主要类别的分配。 有32个主要类。 该主要类别字段的分配在表中定义。
#define AV_MAJOR_DEVICE_CLASS 0x000400
对应 Audio/Video (headset, speaker, stereo, video display, VCR, …
C:\Users\hjw\AppData\Local\YNote\data\weixinobU7VjixR36LtX24EbczQm-GnRPY\0b79ce49b5b345c3a8e6ab4de0580915\clipboard.png
The Minor Device Class field
The Minor Device Class field (bits 7 to 2 in the CoD) is interpreted only in the context of the Major Device Class (but independently of the Service Class field). Thus, the meaning of the bits may change, depending on the value of the Major Device Class field. When the Minor Device Class field indicates a device class, then the primary device class should be reported – e.g., a cellular phone that can also work as a cordless handset should use “Cellular” in the Minor Device Class field.
次要设备类别字段
次要设备类别字段(CoD中的第7至2位)仅在主要设备类别的上下文中进行解释(但独立于服务类别字段)。 因此,比特的含义可以改变,这取决于主要设备类别字段的值。 当“次要设备类别”字段指示设备类别时,则应报告主要设备类别-例如,也可以用作无绳手机的蜂窝电话应在“次要设备类别”字段中使用“蜂窝电话”。
#define HEADSET_MINOR_DEVICE_CLASS 0x000004
主类别是Audio/Video 对应Wearable Headset Device
而0x8对应 Hands-free Device
