查看: 9879|回复: 10
[CSR8系列] CSR8675 resampling i2s output.
发表于 2020-11-2 03:35:05 | 显示全部楼层 |阅读模式
Hello. I have question, maybe you can help me.
Its possible to change resampling of i2s output?
My phone is old, and I have BT 4.2 version. So on i2s output lrclk has 44.1khz , its possible to resample to 48khz?
and if yes, can I have always 48khz or 96khz on i2s output if AG (phone) is 4.2 BT (44.1khz) or 5.0 BT (48khz aptx hd) ?
where I can change this in Sink configuration?
Have a nice day all
签到总奖励:1888金币
发表于 2020-11-2 09:18:59 | 显示全部楼层
 楼主| 发表于 2020-11-2 14:54:35 | 显示全部楼层
Thanks a lot. Its possible to write higher value than 48000? As I see now 65535 is the limit
签到总天数:386天
签到总奖励:3861金币
发表于 2020-11-2 16:05:16 | 显示全部楼层
混淆了吧?你I2S输出采样应该是单独可配置,和你前面44.1和48应该没强制关系吧?
发表于 2020-11-2 16:12:19 | 显示全部楼层
不要低于48000
 楼主| 发表于 2020-11-2 17:33:11 | 显示全部楼层
I need to have one LRCLK for 44.1 and 48khz input.
Without APTX HD there is 44.1khz , with aptx hd is 48khz.
I need to make MCLK generator with one freq to drive AK4490/AK4493 (AK need MCLK, BCLK, LRCLK, DATA).
So Im asking, there is possible to generate 96khz LRCLK i2s output from 44.1/48 AG ? Or 48khz is maximum?
签到总天数:881天
签到总奖励:11162金币
发表于 2020-11-2 17:51:30 | 显示全部楼层
Without APTX HD there is 44.1khz , with aptx hd ...
8675 may not support 96KHz,since the hardware limit;
I think you should check the datasheet of 8675 firstly.
签到总天数:84天
签到总奖励:586金币
发表于 2020-11-2 18:17:21 | 显示全部楼层
蓝牙的SCLK 用 4 倍频就得到 MCLK 信号 。
 楼主| 发表于 2020-11-2 18:27:14 | 显示全部楼层
WS Frequency is 96khz, so 96/2 channels its 48khz. I cant find other table with information about max frequency on PCM output
 楼主| 发表于 2020-11-2 18:29:24 | 显示全部楼层
chzhssr Opublikowany 2020-11-2 18:17
Bluetooth SCLK jest mnożony przez 4 w celu uzyskania sygnału MCLK.
Yes, You are right. AK4493 need 256 * Fs, so for 48kHz MCLK should be 12,288MHz or 24,5760MHz
GMT+8, 2024-4-16 19:38 , Processed in 0.215932 second(s), 21 queries , Gzip On, MemCached On.
