查看: 3830|回复: 0
[音频] ES8156苏州顺芯信噪比110dB低功耗音频DAC芯片,提供设计技术...
发表于 2021-2-1 15:12:42 | 显示全部楼层 |阅读模式
苏州顺芯数字转模拟DAC芯片ES8156
• High peRFormance and low power multibit delta-sigma audio DAC
• 110 dB signal to noise ratio, -80 dB
THD+N 深圳锦宏世纪 李工18938047300
• 24-bit, 8 to 96 kHz sampling frequency
• Integrated headphone driver with
capless option
• Differential output for higher SNR and
CMRR
• I2
S/PCM master or slave serial data port
• 256/384Fs, USB 12/24 MHz and other
non standard audio system clocks
• I2
C interface
• 7-band fully adjustable EQ
• Dynamic range compression
• Playback signal feedback
• Pop and click noise suppression
• 1.8V to 3.3V operation
APPLICATIONS
• Headphone
• Speaker
• TV
• Portable audio devices
ORDERING INFORMATION
ES8156 -40°C ~ +85°C
QFN-20
苏州顺芯DAC系列:ES7134 ES7144 ES7145 ES7154 ES7148 ES7149 ES7154 ES8155 ES8156
ADC系列:ES7210 ES7241 ES7241D ES7242 ES7243  ES7243E ES8218E ES7201 ES7202
Codec系列:ES8316 ES8323S ES8374 ES8388 ES8388S ES8396 ES8311 ES8312
以上型号我司可提供免费样品/DEOM板测试,提供设计资料,提供技术支持!
GMT+8, 2024-4-27 07:04 , Processed in 0.162199 second(s), 15 queries , Gzip On, MemCached On.
