查看: 30054|回复: 1
[中科蓝讯] 8896A datasheet
签到总奖励:18金币
发表于 2021-4-6 10:10:47 | 显示全部楼层 |阅读模式
CPU and Flexible IO
32bit High performance CPU with DSP
instruction
Program memory: internal 4M bit flash
Flexible GPIO pins with Programmable
pull-up and pull-down resistors;
Support GPIO wakeup or interrupt;
Bluetooth Radio
Compliant to Bluetooth 5.0 and BLE
specification (QDID: 115952);
TX output power MAX +8dBm;
RX Sensitivity with -92dBm @2M EDR;
Support TWS communication with
balance-efficiency Power consumption;
Support TWS Master-slave switch;
发表于 2021-4-6 16:57:49 | 显示全部楼层
谢谢分享
GMT+8, 2026-4-7 19:45 , Processed in 0.082695 second(s), 16 queries , Gzip On, MemCached On.
