查看: 139374|回复: 25
[QCC5系列] 关于qcc512x ldac开发的问题
签到总天数:91天
签到总奖励:1662金币
发表于 2021-5-25 22:24:21 | 显示全部楼层 |阅读模式
签到总天数:1220天
签到总奖励:33667金币
发表于 2021-5-26 08:17:04 | 显示全部楼层
Sony 官方的Ldac资料有问题。
签到总天数:66天
签到总奖励:421金币
发表于 2021-6-15 19:49:33 | 显示全部楼层
解决了,但忘了怎么解决的。反正看下那部分代码影响,然后增加的ldac的分支。
签到总天数:168天
签到总奖励:2784金币
发表于 2021-6-16 13:02:47 | 显示全部楼层
EdwardLee 发表于 2021-6-15 19:49
解决了,但忘了怎么解决的。反正看下那部分代码影响,然后增加的ldac的分支。 ...
有大概方法吗
签到总天数:66天
签到总奖励:421金币
发表于 2021-6-17 14:11:14 | 显示全部楼层
大概是这里影响的,跟一下代码,看下那里影响的,增加个分支。
audio_input_a2dp_chain_config_stereo.c
  1. kymera_chain_handle_t audioInputA2dpCreateStereoChainWithoutSplitter(audio_codec_t decoder)
  2. {
  3. #ifdef ENABLE_LDAC_SINK
  4.     if(decoder == audio_codec_ldac)
  5.     {
  6.         operator_config_t filterldac[] = {getDecoderFilterLdac(decoder), getRemoveSplitterFilterLdac()};
  7.         operator_filters_t filtersldac = {.operator_filters = filterldac, .num_operator_filters = ARRAY_DIM(filterldac)};
  8.         return PanicNull(ChainCreateWithFilter(getChainConfig(decoder), &filtersldac));
  9.     }
  10.     else
  11.     {
  12.         operator_config_t filter[] = {getDecoderFilter(decoder), getRemoveSplitterFilter()};
  13.         operator_filters_t filters = {.operator_filters = filter, .num_operator_filters = ARRAY_DIM(filter)};
  14.         return PanicNull(ChainCreateWithFilter(getChainConfig(decoder), &filters));
  15.     }
  16. #else
  17.     operator_config_t filter[] = {getDecoderFilter(decoder), getRemoveSplitterFilter()};
  18.     operator_filters_t filters = {.operator_filters = filter, .num_operator_filters = ARRAY_DIM(filter)};
  19.     return PanicNull(ChainCreateWithFilter(getChainConfig(decoder), &filters));
  20. #endif
  21. }
  22. kymera_chain_handle_t audioInputA2dpCreateStereoChain(audio_codec_t decoder)
  23. {
  24. #ifdef ENABLE_LDAC_SINK
  25.     if(decoder == audio_codec_ldac)
  26.     {
  27.         operator_config_t filterldac[] = {getDecoderFilterLdac(decoder)};
  28.         operator_filters_t filtersldac = {.operator_filters = filterldac, .num_operator_filters = ARRAY_DIM(filterldac)};
  29.         return PanicNull(ChainCreateWithFilter(getChainConfig(decoder), &filtersldac));
  30.     }
  31.     else
  32.     {
  33.         operator_config_t filter[] = {getDecoderFilter(decoder)};
  34.         operator_filters_t filters = {.operator_filters = filter, .num_operator_filters = ARRAY_DIM(filter)};
  35.         return PanicNull(ChainCreateWithFilter(getChainConfig(decoder), &filters));
  36.     }
  37. #else
  38.     operator_config_t filter[] = {getDecoderFilter(decoder)};
  39.     operator_filters_t filters = {.operator_filters = filter, .num_operator_filters = ARRAY_DIM(filter)};
  40.     return PanicNull(ChainCreateWithFilter(getChainConfig(decoder), &filters));
  41. #endif
  42. }
复制代码
签到总天数:168天
签到总奖励:2784金币
发表于 2021-6-17 15:31:08 | 显示全部楼层
好的,谢谢,getDecoderFilterLdac和getDecoderFilter里面的处理啥区别?看起来getDecoderCapabilityId里面也有区分ldac啊。
签到总天数:66天
签到总奖励:421金币
发表于 2021-6-17 17:18:52 | 显示全部楼层
骑着蟑螂去上学 发表于 2021-6-17 15:31
好的,谢谢,getDecoderFilterLdac和getDecoderFilter里面的处理啥区别?看起来getDecoderCapabilityId里 ...
static const operator_config_t op_config[] =
    MAKE_OPERATOR_CONFIG(capability_id_rtp, rtp_role),
    MAKE_OPERATOR_CONFIG(capability_id_splitter, splitter_role),
    MAKE_OPERATOR_CONFIG(capability_id_none, decoder_role)
当初我也是一段段代码加进去,编译,测试,发现的。
AAC这里不是修改的,你分析下op_config的调用,然后创建ldac的分支;
签到总天数:168天
签到总奖励:2784金币
发表于 2021-6-17 18:55:48 | 显示全部楼层
    MAKE_OPERATOR_CONFIG(capability_id_rtp, rtp_role ...
好的,再次感谢,我研究下。
签到总奖励:5金币
发表于 2021-9-5 06:42:08 来自手机 | 显示全部楼层
你能分享评估工具包吗? 我想将其移植到QCC5144
回复 支持 1 反对 0
签到总天数:921天
签到总奖励:16621金币
发表于 2021-9-5 07:14:34 | 显示全部楼层
我也對這個感興趣
GMT+8, 2025-12-21 14:23 , Processed in 0.123700 second(s), 23 queries , Gzip On, MemCached On.
