新手,用MDE编译工程出问题,不知道是工程打开方式不对还是哪里没设置好,编译问题如下,求大神指点。
Exception Name: RuntimeError
Traceback (most recent call last):
File "C:/qtil/ADK_Toolkit_1.2.2.13_x64/tools/ubuild/ubuild.py", line 137, in main
return bld.build_configs(proj_parser, dk_parser, parsed_args)
File "E:\Program\QCC\qcc515x-qcc305x-src-1-0_qtil_standard_oem_earbud-ADK-21.1-CS1-r00066.1-4a6fe982e0f0019f29de652ff133824a2773e71d\adk\tools\packages\builder\build.py", line 1189, in build_configs
return build_filesystem(proj, devkit, script_args, crypto_key, build_output_folder)
File "E:\Program\QCC\qcc515x-qcc305x-src-1-0_qtil_standard_oem_earbud-ADK-21.1-CS1-r00066.1-4a6fe982e0f0019f29de652ff133824a2773e71d\adk\tools\packages\builder\build.py", line 834, in build_filesystem
ps_store_size = get_section_size('rw_config') // 2
File "E:\Program\QCC\qcc515x-qcc305x-src-1-0_qtil_standard_oem_earbud-ADK-21.1-CS1-r00066.1-4a6fe982e0f0019f29de652ff133824a2773e71d\adk\tools\packages\builder\build.py", line 758, in get_section_size
prepare_image = PrepareSingleImage(devkit_root, script_args.workspace_file, None)
File "E:\Program\QCC\qcc515x-qcc305x-src-1-0_qtil_standard_oem_earbud-ADK-21.1-CS1-r00066.1-4a6fe982e0f0019f29de652ff133824a2773e71d\adk\tools\packages\builder\prepare_single_image.py", line 42, in __init__
self._determine_flash_config()
File "E:\Program\QCC\qcc515x-qcc305x-src-1-0_qtil_standard_oem_earbud-ADK-21.1-CS1-r00066.1-4a6fe982e0f0019f29de652ff133824a2773e71d\adk\tools\packages\builder\prepare_single_image.py", line 82, in _determine_flash_config
raise RuntimeError("A valid FLASH_CONFIG was not found")
RuntimeError: A valid FLASH_CONFIG was not found10:20:50: The process "C:\qtil\ADK_Toolkit_1.2.2.13_x64\tools\python27\python.exe" exited with code 1.
Error while building/deploying project ps_cfg (kit: ADK Toolkit 1.2.2.13 x64 - 1.2.2)
When executing step "Build Project"
10:20:50: Elapsed time: 00:06.
