查看: 15380|回复: 7
[Microchip(ISSC)] 1685-304复位三极管击穿问题
签到总天数:141天
签到总奖励:840金币
发表于 2013-10-18 09:22:46 | 显示全部楼层 |阅读模式
签到总奖励:5金币
发表于 2013-10-18 10:29:03 | 显示全部楼层
Can you upload the datasheet?  Or post the URL link of the datasheet.  Then, I can help to check it out.
签到总天数:141天
签到总奖励:840金币
 楼主| 发表于 2013-10-18 10:33:21 | 显示全部楼层
chrischan1911qq 发表于 2013-10-18 10:29
Can you upload the datasheet?  Or post the URL link of the datasheet.  Then, I can help to check it  ...
数据表?我要怎么操作才能得到这些数据。请指教。
签到总奖励:5金币
发表于 2013-10-18 11:14:34 | 显示全部楼层
Not 数据表.  But datasheet, I mean 規格書
签到总天数:141天
签到总奖励:840金币
 楼主| 发表于 2013-10-18 11:59:22 | 显示全部楼层
你意思是三极管的规格书?
签到总奖励:5金币
发表于 2013-10-18 12:25:30 | 显示全部楼层
Yes. Or you can give the detail part number of the 三极管.  I can search on internet.
签到总天数:141天
签到总奖励:840金币
 楼主| 发表于 2013-10-18 14:04:51 | 显示全部楼层
就蓝牙上经常使用到的3904,这个做蓝牙的应该知道吧?我是想问什么情况下才会造成损坏。谢谢。
签到总奖励:5金币
发表于 2013-10-18 14:23:24 | 显示全部楼层
3904 has VCBO=60V, VCEO=40V and VEBO=6V.  For a typical design, there cannot be any voltage higher than these limiting values of the transistor.  If the problem is really on the transistor itself, I guess the quality of the 3904 you used is not good.  Is your 3904 transistor from good brand names (e.g. NXP, On-semi, ...)?
签到总天数:141天
签到总奖励:840金币
 楼主| 发表于 2013-10-18 16:37:46 | 显示全部楼层
chrischan1911qq 发表于 2013-10-18 14:23
3904 has VCBO=60V, VCEO=40V and VEBO=6V.  For a typical design, there cannot be any voltage higher t ...
嗯。好的,谢谢,那我换一家试试。
签到总天数:7天
签到总奖励:26金币
发表于 2013-10-19 09:52:47 | 显示全部楼层
路过,学习中。。。
GMT+8, 2025-6-13 08:50 , Processed in 0.197878 second(s), 21 queries , Gzip On, MemCached On.
