查看: 10159|回复: 2
[BC6系列] PCM Config Utility
发表于 2014-4-7 21:02:02 | 显示全部楼层 |阅读模式
PSKEY_PCM_CONFIG32 is the PSKey that configures thePCM interface on BlueCore. Program the value in RED in to this PSKey. The default value for this key in CSR firmware is0x08000000.
The timing diagram below gives a graphic representation of the waveformsexpected with the current configuration settings.
Bits highlighted in BLUE show the position of Sign Extensionbits.
Bits highlighted in GREEN show the positionof Padding bits for 8-bit samples or audio gain bits for 13-bit samples.
签到总奖励:3金币
发表于 2014-4-8 22:27:35 | 显示全部楼层
CSR8系列上可以使用吗
签到总奖励:3金币
发表于 2014-4-8 22:33:36 | 显示全部楼层
这个工具在哪个包里面呀
GMT+8, 2025-6-8 11:46 , Processed in 0.135993 second(s), 19 queries , Gzip On, MemCached On.
