查看: 77155|回复: 24
[络达(Airoha)] 请教一下这个是哪个方案,可以升级哪个固件
签到总天数:12天
签到总奖励:58金币
发表于 2020-12-19 14:38:54 | 显示全部楼层 |阅读模式
三代耳机,有降噪和通透,但是不确定是否1562a。
重置耳机的过程只有白灯快闪和慢闪,和网上描述的艾创力和HR方案都对不上。
谢谢
发表于 2020-12-19 15:46:01 | 显示全部楼层
Dont upgrade iTronic firmware, they are incompatible with other firmwares such as TigerBuilder etc. Yes this is AB1562A chip since the firmware version is 1.1.1.1
发表于 2020-12-19 20:37:30 | 显示全部楼层
这个版本的确是1562
签到总天数:12天
签到总奖励:58金币
 楼主| 发表于 2020-12-20 12:44:49 | 显示全部楼层
xwintk 发表于 2020-12-19 15:46
Dont upgrade iTronic firmware, they are incompatible with other firmwares such as TigerBuilder etc.  ...
Thanks Bro, also I would like to know if there is any firnware for this version, I also find Donghuan HR firmware which has 4 files in the zip, and he package name is A3_plus_v315, is it compatible with the hardware i have? Cheers!
签到总天数:12天
签到总奖励:58金币
 楼主| 发表于 2020-12-20 12:47:54 | 显示全部楼层
15139299971 发表于 2020-12-19 20:37
这个版本的确是1562
谢谢,不知能刷哪个版本固件
发表于 2020-12-20 23:07:10 | 显示全部楼层
Thanks Bro, also I would like to know if there is any firnware for this version, I also find Donghuan HR firmware which has 4 files in the zip, and he package name is A3_plus_v315, is it compatible with。 the hardware i have? Cheers!
Send me the firmware and I will test, I have a iTronic too that I bought for experiments
发表于 2020-12-21 01:03:27 来自手机 | 显示全部楼层
好像acl的
签到总天数:12天
签到总奖励:58金币
 楼主| 发表于 2020-12-21 10:51:46 | 显示全部楼层
Here you go, by the way, the hardware I got has no white noise when ANC is on, which is perfect
https://wwa.lanzous.com/iteNjj22lfe
签到总奖励:5金币
发表于 2020-12-21 11:23:15 | 显示全部楼层
怎么下载这个软件
发表于 2020-12-21 14:37:10 | 显示全部楼层
Alright, downloaded... Will be testing right now
GMT+8, 2025-6-18 12:58 , Processed in 0.101506 second(s), 22 queries , Gzip On, MemCached On.
