[QCC3系列] 3024,ADK6.3.1,如何设置充电时可以正常开关机运行
 楼主| 发表于 2021-10-28 11:32:26 | 显示全部楼层
黄超人#huang 发表于 2021-7-30 19:19
你是想说在充电的时候,通过按键让耳机开机然后正常连接手机使用对吧?
如果是这样,只要在事件配置那里添 ...
Hi 前辈好,前12项按你的建议修改,出来的打印是Attaching to Device @ "tc:usb2tc:108"...
2 windowed masters
Device attach succeeded.
device = qcc512x_qcc302x-lab
chip = qcc512x_qcc302x-r02-v0
----.---    apps1: Processor 1
----.---    apps1: Firmware ID 1635390371
----.---    apps1: IPC Other processor has Trap API v9.3.0
----.---    apps1: PDLSize[9]
----.---    apps1: MAIN Boot took 247083 instructions, 51944 stalls, 619639 clocks
----.---    apps1: CL[5000] (CL_INIT_CFM)
----.---    apps1: HFP[5a00] (HFP_INIT_CFM)
----.---    apps1: FAULT 0x9 0x0 (FAULT_IPC_PIO_NO_EFFECT)
----.---    apps1: MP Disable Discoverable -p
----.---    apps1: INIT: DeviceClass:0x2360344
----.---    apps1: INIT: complete
----.---    apps1: UE[4095] (EventUsrChargerConnected)
----.---    apps1: HS: Charger Connected
----.---    apps1: HFP[5a04] (HFP_SLC_DISCONNECT_IND)
----.---    apps1: UE[47bd] (EventSysUpdateDevicesConnectedStatus)
----.---    apps1: CL[5024] (CL_SM_SEC_MODE_CONFIG_CFM)
----.---    apps1: CL[5055] (CL_DM_WRITE_INQUIRY_MODE_CFM)
----.---    apps1: CL[5030] (CL_SDP_REGISTER_CFM)
----.---    apps1: UE[4099] (EventUsrAnalogAudioDisconnected)
----.---    apps1: UE[47e3] (EventSysAnalogueAudioDisconnectTimeout)
----.---    apps1: CL[5008] (CL_DM_READ_INQUIRY_TX_CFM)
----.---    apps1: CL[5007] (CL_DM_LOCAL_NAME_COMPLETE)
----.---    apps1: UE[470a] (EventSysBatteryOk)
----.---    apps1: UE[4714] (EventSysChargerGasGauge3)
----.---    apps1: HFP[5a2e] (HFP_AT_CMD_CFM)
----.---    apps1: UE[471e] (EventSysLongTimer)
----.---    apps1: UE[4709] (EventSysChargeInProgress)
----.---    apps1: LED 0 initialised
----.---    apps1: LED 1 initialised
----.---    apps1: UE[4746] (EventSysCheckAudioRouting)
----.---    apps1: UE[471f] (EventSysVLongTimer)
1408.681    apps1: UE[4708] (EventSysChargeComplete)
1408.681    apps1: HS: EventSysChargeComplete
1414.644    apps1: UE[471e] (EventSysLongTimer)
1416.143    apps1: UE[471f] (EventSysVLongTimer)
1416.147    apps1: UE[4001] (EventUsrPowerOn)
1416.147    apps1: HS: Power On
1416.154    apps1: MP Enable Connectable -i
1416.177    apps1: DIS[3]
1416.183    apps1: UE[4096] (EventUsrChargerDisconnected)
1416.183    apps1: HS: Charger Disconnected
1416.205    apps1: UE[4095] (EventUsrChargerConnected)
1416.205    apps1: HS: Charger Connected
1416.270    apps1: UE[4786] (EventSysLEDIndicateState)
1416.761    apps1: UE[470a] (EventSysBatteryOk)
1416.764    apps1: UE[4714] (EventSysChargerGasGauge3)
1416.764    apps1: UE[47e0] (EventSysEQOn)
1416.764    apps1: UE[47bd] (EventSysUpdateDevicesConnectedStatus)
1416.764    apps1: UE[4721] (EventSysCancelLedIndication)
1416.764    apps1: HS: Disable LED indication
1416.956    apps1: HFP[5a2e] (HFP_AT_CMD_CFM)
1416.959    apps1: HFP[5a2e] (HFP_AT_CMD_CFM)
1417.643    apps1: UE[471f] (EventSysVLongTimer)
1418.680    apps1: UE[4757] (EventSysCheckAudioAmpDrive)
1418.680    apps1: HS : EventSysCheckAudioAmpDrive turn off amp
1418.686    apps1: HS : Audio prompt done
1419.176    apps1: UE[4720] (EventSysEnablePowerOff)
1419.179    apps1: HS: EventSysEnablePowerOff
又被关机了,你指的“开机函数没有在充电判断不开机”是干掉powerManagerChargerConnected这个函数吗?
回复
签到总天数:326天
签到总奖励:2269金币
发表于 2021-10-28 12:03:12 | 显示全部楼层
config tool里配置 system--allow aoto power off when charging
回复
 楼主| 发表于 2021-10-28 13:29:34 | 显示全部楼层
这个已经试过,充电时开不了机。
回复
签到总天数:326天
签到总奖励:2269金币
发表于 2021-10-29 14:00:25 | 显示全部楼层
┌.靈魂mi.夨 发表于 2021-10-28 13:29
这个已经试过,充电时开不了机。
user button 里吧VCHG 取消就好了
回复
 楼主| 发表于 2021-11-2 11:19:12 | 显示全部楼层
这个软件我们VCHG一直都是没用到的。。。
回复
签到总天数:127天
签到总奖励:869金币
发表于 2021-11-13 18:09:49 | 显示全部楼层
subsys7_config2.htf里面把这句注释就可以了,这是充电时强制关机复位的  ResetOnChargerAttach = true
回复
签到总天数:45天
签到总奖励:288金币
发表于 2021-12-15 11:56:01 | 显示全部楼层
lulu7320198 发表于 2021-11-13 18:09
subsys7_config2.htf里面把这句注释就可以了,这是充电时强制关机复位的  ResetOnChargerAttach = true ...
+1
回复
连续签到天数:3天
签到总天数:244天
签到总奖励:3382金币
发表于 2023-1-11 10:25:48 | 显示全部楼层
为啥3024 默认工程里面,subsys7_config2.htf 文件中没有这句话
竟然没有招了,充电关机
回复
GMT+8, 2025-5-24 13:44 , Processed in 1.313360 second(s), 18 queries , Gzip On, MemCached On.
