查看: 5096|回复: 0
[其他] Wallys|DR8072A(HK09) Support WiFi 6E Card,802.11ax QCN9074
发表于 2022-8-31 14:59:18 | 显示全部楼层 |阅读模式
    Features■ Qualcomm Atheros IPQ8072A AR Quad Core CPU
    ■ On-board 5GHz radio, up to 2475 Mbps physical data rate 8 MB NOR Flash, 256MB NAND Flash
    ■ On-board 2.4GHz radio, up to 1147Mbps physical data rate
    ■ Support 802.11ac TX Beamforming
    ■ Support 802.11ac/802.11ax MU-MIMO DL and UL
    ■ Support OFDMA DL and UL
    ■ Tri-band support with 5G SBS (4x4/5GHz ) + 4x4/2.4GHz
    Absolute Maximum Rating
    Parameter
    Rating
    Unit
    Operating Temperature Range
    -20 to +70
    oC
    Storage Temperature Range
    -40 to +90
    oC
    Operating Humidity Range
    5 to +95 (non-condensing)
    Storage Humidity Range
    0 to +90 (non-condensing)
    Hardware Specifications
    Symbol
    Parameter
    CPU
    Qualcomm Atheros Quad Core ARM Cortex 64-bit A53 Processor IPQ8072A 2.2GHz CPU
    CPU Frequency
    Derived from Qualcomm Atheros AP.HK09
    System Memory
    1x 512MB, DDR4 2400MHz 16-bit interface
    Frequency Range
    2.412~2.472GHz,
    5.150~5.825GHz
    MiniPCIe Slot
    1x MiniPCIe Slot with PCIe 3.0
    Modulation Techniques
    OFDMA: BPSK, QPSK, 16-QAM, 64-QAM, 256-QAM, 1024-QAM
    Environmental Temperature
    Operating: -20oC to 70oC,
    Storage: -40oC to 90oC
    Flash
    NOR Flash: 8 MB
    NAND Flash: 256MB
    Wireless
    On-board 4x4 2.4GHz MU-MIMO OFDMA 802.11b/g/n/ax, max 17dBm per chain
    On-board 4x4 5GHz MU-MIMO OFDMA 802.11a/n/ac/ax, max 17dBm per chain
    8x U.FL Connectors
    Reset Buttons
    1x S/W Reset Button
    DC Jack Input
    1x DC Jack Connector: 12V
    Interface
    4x 1Gbps Ethernet Port,
    2x 2.5Gbps Ethernet Port
    2x USB 3.0 Port
    1x JTAG 20 Pin Connector
    1x Serial Port 4 Pin Connector
    LED
    2x RGB LED Indicators
    Power Consumption
    TBD
    https://www.wallystech.com/Routerboard/DR8072A-HK09-wifi6-Qualcomm-IPQ8072A-4T4R-2-2.5GE-port-support-OpenWRT-802.11AX-MU-MIMO-OFDMA.html
    Wallys Communications (Suzhou ) Co., LTD
    Emailsales1@wallystech.com
GMT+8, 2025-9-13 04:22 , Processed in 0.123477 second(s), 17 queries , Gzip On, MemCached On.
