查看: 3635|回复: 0
[其他] Wallys|QSDK IPQ5018, 802.11ax QCN9074 2.4G 2x WiFi 6E Card
签到总奖励:18金币
发表于 2022-10-11 10:37:58 | 显示全部楼层 |阅读模式
Qualcomm IPQ5018 dual-core CPU, the main frequency is 1GHz. In terms of performance, there is not much to say. It supports 160Hz bandwidth and 4K QAM modulation mode, and the dual-band six-channel wireless rate is up to 5400Mbps, which is 20% higher than the peak rate of ordinary WiFi6. Six high-power independent FEMs are built in to enhance the signal with one Turbo click.
wallys, a technology company that develops, designs and manufactures wireless communications products, has 90% of the world’s customers and is a supplier to facebook.
From 802.11n to 802.11ax, it has been moving forward, and has been trusted and supported by more and more customers.
wallys also supports custom development of software and hardware, including customized products.
Skype/EMAIL:sales@wallystech.com
DR5018
Dual-core ARM 64bit A53@1.0GHz Processor
512MB DDRL3L System Memory
4MB NOR Flash, 128MB NAND Flash
2x2 On-board 2.4GHz radio,up to 573Mbps physical Data Rate
Support BT5.1
M.2 Card Slot for 5G (QUECTEL RM 500Q-GL) ;
M.2 Card Slot for QCN9074 WIFI 6E Card
Wireless chip for Qualcomm QCN9074, 5G wireless chip, support 160MHz 4x4MIMO, high rate 4804Mbps, support 4096-QAM modulation (2x2MIMO) large band is 512.
It’s not just WiFi6, it actually supports WiFi6E, don’t underestimate this E, WiFi6E is working in the 6GHz band.
■ Qualcomm Atheros QCN9074
■ 6GHz, max 23dBm per chain, up to 4949Mbps
■ Single Band 6GHz 4x4 WiFi 6E (802.11ax)
■ 4 spatial streams (4SS)
■ M.2 E Key Interface
■ PCI Express 3.0 Interface
GMT+8, 2025-5-25 11:59 , Processed in 0.123549 second(s), 13 queries , Gzip On, MemCached On.
