查看: 2268|回复: 4
[QCC5系列] 请教编译错误的问题
签到总天数:100天
签到总奖励:3647金币
发表于 2023-5-14 09:21:03 | 显示全部楼层 |阅读模式
悬赏10金币已解决
MDE:MDE WIN 2.8.0.37 _x64
ADK:ADK_QCC512X_QCC302X_WIN_6.4.2.26
SDK:adk-src-1-0_qtil_standard_oem_qcc517x-qcc307x-ADK-22.1-CS-r00122
-TOP LEVEL ELEMENTS-
  info          :True
  commands      :True
  toolchain     :True
  ext_id        :True
  doc           :True
  ext_info      :True
  locks         :True
  plugins       :True
  configurations:True
    -COMMANDS-
      coredumpWithAppsSqif:{'run': './tools/python27/python.exe', 'description': 'Coredump all sub-systems including apps sqif'}
      eraseApps           :{'run': './tools/python27/python.exe', 'description': 'Run pydbg to erase the apps area'}
      config_tool         :{'run': './tools/bin/ADKConfigTool.exe', 'description': 'Run the config tool'}
      setMemoryOption     :{'run': './tools/python27/python.exe', 'description': 'Setup Memory Module Type to support'}
      scramble_aspk       :{'run': './tools/python27/python.exe', 'description': 'Scramble ASPK'}
      deploy              :{'run': './tools/python27/python.exe', 'description': 'Deploys an ADK Project binary to a device'}
      make                :{'run': 'bin/make.exe', 'description': 'GNU Make'}
      coredump            :{'run': './tools/python27/python.exe', 'description': 'Coredump all sub-systems'}
      versions_workspace  :{'run': './tools/python27/python.exe', 'description': 'Discover versions of various workspace files'}
      privateLibExport    :{'run': './tools/python27/python.exe', 'description': 'Import a private private library into a project'}
      buildDFU            :{'run': './tools/python27/python.exe', 'description': 'Collect or build input files and create DFU file'}
      build               :{'run': './tools/python27/python.exe', 'description': 'Builds an ADK Project'}
      clean               :{'run': './tools/python27/python.exe', 'description': 'Clean an ADK Project'}
      pydbgCoredump       :{'run': './tools/python27/python.exe', 'description': 'Run pydbg on a coredump'}
      dfu_setup           :{'run': './tools/python27/python.exe', 'description': 'Setup DFU security'}
      buildFlashImage     :{'run': './tools/python27/python.exe', 'description': 'Generate a single flash image file'}
      versions_devkit     :{'run': './tools/python27/python.exe', 'description': 'Discover versions of various devkit files'}
      privateLibImport    :{'run': './tools/python27/python.exe', 'description': 'Import a private private library into a project'}
-TOOLS-
  system:{'device': 'plugins/debugger/device_control_hydra.dll', 'core_groups': {'app': {'p1': 'plugins/debugger/core_debug_kalimba.dll'}, 'audio': {'p0': 'plugins/debugger/core_debug_kalimba.dll', 'p1': 'plugins/debugger/core_debug_kalimba.dll'}}}
09:19:34: The process "C:\qtil\ADK_QCC512X_QCC302X_WIN_6.4.2.26\tools\python27\python.exe" exited with code 1.
Copying files to customer_ro filesystem...
Copying files added to customer_ro filesystem project...
Copying file E:\qcc517x-qcc307x-ADK-22.1\earbud\prompts\connected.sbc
Copying file E:\qcc517x-qcc307x-ADK-22.1\earbud\prompts\disconnected.sbc
Copying file E:\qcc517x-qcc307x-ADK-22.1\earbud\prompts\pairing.sbc
Copying file E:\qcc517x-qcc307x-ADK-22.1\earbud\prompts\pairing_failed.sbc
Copying file E:\qcc517x-qcc307x-ADK-22.1\earbud\prompts\pairing_successful.sbc
Copying file E:\qcc517x-qcc307x-ADK-22.1\earbud\prompts\power_off.sbc
Copying file E:\qcc517x-qcc307x-ADK-22.1\earbud\prompts\power_on.sbc
Copying file E:\qcc517x-qcc307x-ADK-22.1\audio\qcc517x_qcc307x\kalimba_ROM_14612\kymera\prebuilt_dkcs\maor_rom_release\download_aanc2.edkcs
Copying file E:\qcc517x-qcc307x-ADK-22.1\audio\qcc517x_qcc307x\kalimba_ROM_14612\kymera\prebuilt_dkcs\maor_rom_release\download_anc_compander.edkcs
Copying file E:\qcc517x-qcc307x-ADK-22.1\audio\qcc517x_qcc307x\kalimba_ROM_14612\kymera\prebuilt_dkcs\maor_rom_release\download_anc_hw_manager.edkcs
Copying file E:\qcc517x-qcc307x-ADK-22.1\audio\qcc517x_qcc307x\kalimba_ROM_14612\kymera\prebuilt_dkcs\maor_rom_release\download_anc_tuning.edkcs
Copying file E:\qcc517x-qcc307x-ADK-22.1\audio\qcc517x_qcc307x\kalimba_ROM_14612\kymera\prebuilt_dkcs\maor_rom_release\download_aptx_adaptive_r3_decode.edkcs
Copying file E:\qcc517x-qcc307x-ADK-22.1\audio\qcc517x_qcc307x\kalimba_ROM_14612\kymera\prebuilt_dkcs\maor_rom_release\download_hcgr.edkcs
Copying file E:\qcc517x-qcc307x-ADK-22.1\audio\qcc517x_qcc307x\kalimba_ROM_14612\kymera\prebuilt_dkcs\maor_rom_release\download_lc3_decode_sco_iso.edkcs
Copying file E:\qcc517x-qcc307x-ADK-22.1\audio\qcc517x_qcc307x\kalimba_ROM_14612\kymera\prebuilt_dkcs\maor_rom_release\download_lc3_encode_sco_iso.edkcs
Copying file E:\qcc517x-qcc307x-ADK-22.1\audio\qcc517x_qcc307x\kalimba_ROM_14612\kymera\prebuilt_dkcs\maor_rom_release\download_splitter.edkcs
Copying file E:\qcc517x-qcc307x-ADK-22.1\audio\qcc517x_qcc307x\kalimba_ROM_14612\kymera\prebuilt_dkcs\maor_rom_release\download_swbs.edkcs
Copying file E:\qcc517x-qcc307x-ADK-22.1\audio\qcc517x_qcc307x\kalimba_ROM_14612\kymera\prebuilt_dkcs\maor_rom_release\download_va_graph_manager.edkcs
Copying file E:\qcc517x-qcc307x-ADK-22.1\audio\qcc517x_qcc307x\kalimba_ROM_14612\kymera\prebuilt_dkcs\maor_rom_release\download_wind_noise_detect.edkcs
FS_ROOT directory does not exist
Error while building/deploying project ro_fs (kit: ADK QCC512X QCC302X WIN 6.4.2.26 - 6.4.2)
When executing step "Build Project"
09:19:34: FAILED to complete all steps
09:19:34: Elapsed time: 00:06.
最佳答案
查看完整内容
ADK不合适
发表于 2023-5-14 09:21:04 | 显示全部楼层
ADK不合适
回复
签到总天数:100天
签到总奖励:3647金币
 楼主| 发表于 2023-5-14 10:59:25 | 显示全部楼层
问题解决,在目录earbud\workspace\QCC3071-AA_DEV-BRD-R3-AA\下创建一个目录customer_ro_filesystem即可
回复
签到总天数:200天
签到总奖励:5781金币
发表于 2023-5-15 15:16:25 | 显示全部楼层
恭喜
回复
签到总天数:100天
签到总奖励:3647金币
 楼主| 发表于 2023-5-31 23:11:07 | 显示全部楼层
回复
GMT+8, 2025-5-25 12:18 , Processed in 1.703680 second(s), 21 queries , Gzip On, MemCached On.
