楼主: 等等就来
[QCC3系列] QCC3084打开LED1,LED2,LED3的方法。
连续签到天数:4天
签到总天数:199天
签到总奖励:1636金币
发表于 2023-9-26 09:03:50 | 显示全部楼层
谢谢。
发表于 2023-10-24 21:06:42 | 显示全部楼层
thanks
发表于 2023-11-1 23:41:07 | 显示全部楼层
Thanks for sharing, studying
发表于 2023-11-7 09:42:43 | 显示全部楼层
pla landlord, what about the 5144, what value and which file i need to edit ,
pio_if.h
pio_common.h
headset_led.h
headset_leds_config_table.c
headset_led.c
pio_common.h
which one i need to edit, not seen sililar to CHIP_LED_BASE_PIO=58, CHIP_NUM_LEDS=3, and change HAVE_1_LED to HAVE_3_LEDS. R
发表于 2023-11-7 12:39:46 | 显示全部楼层
i found from file headset.debug.mak, here we need to change ?
BUILDOUTPUT_PATH=depend_debug_qcc514x_qcc304x
BUILD_ID=../../../adk/tools/packages/buildid/examples/adk_buildid.py
BUILD_TYPE=RELEASE
CHIP_NAME=QCC514x_apps
CHIP_TYPE=qcc514x_qcc304x
DBG_CORE=app/p1
DEFAULT_LIBS=usb_early_init
DEFS=APTX_ADAPTIVE_SUPPORT_96K \
    AV_DEBUG \
    BLUELAB \
    BOARD_TX_POWER_PATH_LOSS=236 \
    CHIP_LED_BASE_PIO=58 \
    CHIP_NUM_LEDS=3 \
    DEBUG \
    DISABLE_ABSOLUTE_VOLUME_SUPRESSION \
    DISABLE_TWS_PLUS \
    DOWNLOAD_VOLUME_CONTROL \
发表于 2023-11-7 21:13:52 | 显示全部楼层
what is the value of CHIP_LED_BASE_PIO for 5144 ?, plz help
签到总天数:424天
签到总奖励:6562金币
发表于 2023-11-8 11:15:29 | 显示全部楼层
这个代码应该能找到定义吧
发表于 2023-11-8 11:49:48 | 显示全部楼层
i kept the CHIP_LED_BASE_PIO=74, and 3 LEDS , still it not flashing it only glow, no pattern , any thing is missing in my setting
签到总天数:64天
签到总奖励:2015金币
发表于 2023-11-13 18:20:20 | 显示全部楼层
学习
连续签到天数:6天
签到总天数:945天
签到总奖励:26950金币
发表于 2023-11-14 15:28:25 | 显示全部楼层
manish12 发表于 2023-11-8 11:49
i kept the CHIP_LED_BASE_PIO=74, and 3 LEDS , still it not flashing it only glow, no pattern , any t ...
the ADK only use the pure PIO but not PWM for a low power consumption.
but you can add PWM function as you wish.
GMT+8, 2025-6-3 04:27 , Processed in 0.154345 second(s), 21 queries , Gzip On, MemCached On.
