查看: 4485|回复: 4
[QCC3系列] activating third-party codecs in qcc3024
签到总天数:13天
签到总奖励:102金币
发表于 2023-11-7 18:36:27 | 显示全部楼层 |阅读模式
Hello, I don’t know if it’s possible to write in English on this forum, but I’ll try.  Some time ago I purchased headphones based on qcc3024, as far as I understand it is the twin brother of the qcc3034 chip, but without aptx support.  The question is, is there any way to make it work with other codecs?  I heard somewhere on another forum that you can change the parameter so that the chip is identified as a different model, is this true?
签到总天数:477天
签到总奖励:12061金币
发表于 2023-11-7 20:51:20 | 显示全部楼层
qcc3024可以开启aptx功能,但是需要购买license
签到总天数:64天
签到总奖励:2015金币
发表于 2023-11-13 18:21:46 | 显示全部楼层
学习
签到总天数:13天
签到总奖励:102金币
 楼主| 发表于 2023-11-15 04:27:11 | 显示全部楼层
how i can do it on existing firmware? or can i use education bluetooth address/license key as on CSR chipset?
签到总天数:40天
签到总奖励:263金币
发表于 2025-4-7 23:32:51 | 显示全部楼层
thank you
GMT+8, 2025-5-28 01:06 , Processed in 0.767207 second(s), 17 queries , Gzip On, MemCached On.
