查看: 3124|回复: 4
[CSR8系列] CSR8675 question about connecting
发表于 2024-7-28 03:29:58 | 显示全部楼层 |阅读模式
Hello,
I have two question about CSR8675.
1) Its possible to connect at same time 2 devices (for example 2 phones) to same CSR8675? And play music from both phones on same time? Or when one phone is playing, then second cant play, but when first phone has stopped music , then second can play without disconecting? Something like party mode? Its possible to connect 2 devices to one csr8675 at same time? If yes, its possible to make changes with Sink software? Or maybe its called "multipoint"?
2) Its possible to change ID of CSR8675? Situation:
- I have 2 CSR8675, two different BT name, like "CSR8675 A" and second "CSR8675 B", but they have same ID and my phone cant connected properly between "A" and "B". Should I change vendor ID, product id or maybe bcd version?
Thanks for your help
Mateusz
签到总天数:492天
签到总奖励:12147金币
发表于 2024-7-29 10:18:12 | 显示全部楼层
1. 可以同时连接两部手机,通常第一步连接的手机优先播放。 2. 只要蓝牙地址不同就不存在问题
 楼主| 发表于 2024-7-29 12:52:51 | 显示全部楼层
Hi, thank you for reply
1) I cant connect 2 phones at same time. When Im connected from mobile "A", then mobile "B" get error that cant connect with CSR8675. I need disconnect mobile "A", then mobile "B" can connect. Can I fix it with Sink?
2) Ok, but where I can find address in sink?
Configuration Set -> Device and Software version
or with PStool?
签到总天数:492天
签到总奖励:12147金币
发表于 2024-7-29 14:40:50 | 显示全部楼层
1) I cant connect 2 phones at same time. When Im connected from mobile "A", ...
1. 需要开启multipoint功能
2. 使用pstool修改蓝牙地址
 楼主| 发表于 2024-7-29 17:34:04 | 显示全部楼层
1) Just in Sink? "enable multipoint in hfp library" or "enable multipoint in vm app"
2) thanks
GMT+8, 2025-9-18 02:53 , Processed in 0.192104 second(s), 17 queries , Gzip On, MemCached On.
