查看: 674|回复: 9
[CSR8系列] CSR8675 + aptx lossless?
发表于 2025-2-4 16:21:31 | 显示全部楼层 |阅读模式
Hello,
Im using CSR8675 with SBA, AAC, aptx, apth HD codecs. Its possible to add the newest aptx lossless? If yes, how to do it?
Regards
签到总天数:865天
签到总奖励:16117金币
发表于 2025-2-4 20:53:39 | 显示全部楼层
Of course not. aptX Lossless is a special mode of aptX Adaptive R2.2 which needs special hardware to function.
 楼主| 发表于 2025-2-4 21:28:07 | 显示全部楼层
Thanks for answer. Where I can find table with bluetooth version which can work with aptx lossless?
签到总天数:865天
签到总奖励:16117金币
发表于 2025-2-4 23:36:51 | 显示全部楼层
It's not about the Bluetooth version, but rather about Qualcomm extensions, namely QHS. It should be supported starting from QCC514x, but the actual "lossless" is only available in QCC517x+ (including QCC52xx and QCC72xx)
 楼主| 发表于 2025-2-5 05:04:47 | 显示全部楼层
Yes, I have asked about BT hardware like QCC3086 and others chips. On qualcomm site I found that the newest chipset is QCC3084; QCC5181 or Im wrong?  Im looking for new BT with lossless codec + i2s output and with good documentation/software.
签到总天数:44天
签到总奖励:280金币
发表于 2025-2-6 09:01:38 | 显示全部楼层
thank you
签到总天数:865天
签到总奖励:16117金币
发表于 2025-2-6 21:19:39 | 显示全部楼层
The newest are QCC7226/8 and QCC5229, but you can't buy them that easily. The next best option is QCC5181.
Software and documentation are quite bad for all of chips.
 楼主| 发表于 2025-2-6 21:36:47 | 显示全部楼层
I see. Thank you. There is on forum somebody who knows dev QCC5181 and can program software with defined functions?
签到总天数:44天
签到总奖励:280金币
发表于 2025-2-10 12:45:15 | 显示全部楼层
thank you
签到总天数:44天
签到总奖励:280金币
发表于 2025-3-2 10:18:05 | 显示全部楼层
thank you
GMT+8, 2025-6-21 12:30 , Processed in 0.124490 second(s), 22 queries , Gzip On, MemCached On.
