查看: 195|回复: 0
[供应] Qualcomm QCN9274/QCN6274 Wi-Fi 7 Card x86 & Ubuntu Compatible
发表于 2025-4-1 09:45:34 | 显示全部楼层 |阅读模式
Wallys DR9274 Wi-Fi 7 PCIe Card
QCN9274/QCN6274 Chip | x86 & Ubuntu Support | Enterprise-Grade Networking
High-Density, Low-Latency Wireless Solutions for Industrial IoT & Enterprise WiFi 7 Deployments
Introduction: The Next Era of Enterprise Wireless Connectivity
The rapid evolution of Wi-Fi 7 (IEEE 802.11be) is revolutionizing enterprise networks, demanding hardware that combines cutting-edge performance with seamless integration. The Wallys DR9274 PCIe Wireless Card, powered by Qualcomm QCN9274/QCN6274 chips, emerges as a game-changer. Designed for x86 architecture and fully compatible with Ubuntu systems, this module delivers multi-gigabit speeds, industrial-grade reliability, and future-proof scalability — ideal for high-stakes environments like smart factories, dense office networks, and mission-critical IoT deployments.
5 Key Advantages of Wallys DR9274 Wi-Fi 7 Modules1. x86 & Ubuntu Compatibility: Unleash Developer Flexibility
  • Native x86 Support: Seamlessly integrates with Intel/AMD-based servers, industrial PCs, and edge gateways, eliminating driver conflicts.
  • Ubuntu 22.04 LTS Optimization: Pre-certified drivers and SDKs enable rapid deployment on Linux environments, with full access to OpenWRT/OpenWiFi for custom network policies.
  • Use Case: Deploy as a software-defined access point (SDAP) or cloud-managed wireless controller on existing x86 infrastructure.
2. Wi-Fi 7 Performance: Redefining Wireless Limits
  • 320MHz Channel Bandwidth: Achieves ~40Gbps aggregate throughput — 2x faster than WiFi 6E.
  • 4K QAM Modulation: Boosts data density by 20%, enhancing bandwidth-hungry applications like 8K video streaming and AR/VR.
  • Multi-Link Operation (MLO): Transmits data across 2.4GHz, 5GHz, and 6GHz bands, reducing latency to <1ms for industrial automation.
3. Flexible Deployment: Single/Dual-Band Configurations
  • Single-Band Models: Optimized for interference-free 6GHz backhaul or dedicated 5GHz IoT sensor networks.
  • Dual-Band Models: Combine 5GHz+6GHz for enterprise-grade mesh networks or 2.4GHz+5GHz for legacy device compatibility.
  • Example: Deploy 5GHz+6GHz dual-band cards in stadiums to handle 10,000+ concurrent users with zero packet loss.
4. Industrial Durability: Built for Harsh Environments
  • Extended Temperature Range: Operates at -40°C to +85°C, certified for outdoor smart grids and factory floors.
  • Hardened Security: Supports WPA3-Enterprise, AES-256 encryption, and Secure Boot to meet NIST compliance.
  • Open-Source Firmware: Customize QoS rules, VLAN tagging, and spectrum analysis via OpenWRT.
5. Qualcomm QCN9274/QCN6274: A Proven Silicon Foundation
  • 16-Stream MU-MIMO: Supports 500+ devices per card with dynamic beamforming.
  • Hardware Accelerators: Offloads CPU load for tasks like packet prioritization and intrusion detection.
Application Scenarios: Where Wi-Fi 7 Drives Transformation1. Enterprise Wi-Fi 7 Networks
  • High-Density Offices: Support 200+ users per AP with zero buffering in 4K video conferencing.
  • HD Telemedicine: Enable real-time transmission of MRI/CT scans over 6GHz wireless links.
2. Industrial IoT & Automation
  • AGV Fleet Control: Achieve sub-millisecond latency for robotic coordination in smart warehouses.
  • Wireless PLCs: Replace wired EtherCAT networks with secure 5GHz wireless loops.
3. Carrier & Smart City Infrastructure
  • Wireless Backhaul: Replace fiber with 6GHz point-to-point links for 5G small cell aggregation.
  • Public Wi-Fi 7 Hotspots: Deploy in airports or malls with captive portals and AI-driven traffic shaping.
4. Defense & Mission-Critical Systems
  • Tactical Mesh Networks: Build self-healing wireless grids using MLO and 4K QAM.
  • Drone Command Centers: Stream 360° LiDAR data via 320MHz channels.
Conclusion: Future-Proof Your Wireless Infrastructure Today
The Wallys DR9274 Wi-Fi 7 PCIe Card transcends traditional wireless limitations by merging Qualcomm’s silicon excellence, x86/Ubuntu adaptability, and industrial resilience. Whether upgrading enterprise networks, automating factories, or building smart city backbones, this module delivers unparalleled speed, reliability, and control.
Act Now:
  • Request a customized performance benchmark for your use case.
  • Explore OEM/ODM options for bulk deployments.
  • Download Ubuntu driver packages and API documentation.
GMT+8, 2025-6-13 09:28 , Processed in 0.219739 second(s), 12 queries , Gzip On, MemCached On.
