查看: 4001|回复: 3
[QCC3系列] jbl最新的便携音箱支持auracast,无法搜索到qcc3086?
签到总天数:495天
签到总奖励:12160金币
发表于 2025-4-12 23:14:45 | 显示全部楼层 |阅读模式
比如jbl go4,jbl clip5,通过测试发现他们的广播源应该使用的tmap,32k。尝试把qcc3086的参数也改为相同的,依旧无法搜索连接。奇怪了。
这里顺便把jbl go4的pts测试数据发出来,大家可以共同研究。
  1. Test case : TMAP/BMS/ASC/BV-01-C started
  2. - Received Data: Broadcast Audio Announcements:
  3.     Length: [6 (0x06)]
  4.     AD Type: [22 (0x16)] Service Data AD Data Type
  5.     Broadcast Audio Announcements Service UUID: [6226 (0x1852)] Service UUID
  6.     Broadcast ID: [33029 (0x008105)]
  7. - Received Data: Basic Audio Announcements:
  8.     Length: [67 (0x43)]
  9.     AD Type: [22 (0x16)]
  10.     Basic Audio Announcement Service UUID: [6225 (0x1851)] Service UUID
  11.     Presentation Delay: [80000 (0x013880)]
  12.     Num Subgroups: [1 (0x01)]
  13.     Codec And Metadata Subgroups: {
  14.     Num BIS: [2 (0x02)]
  15.     Codec And Metadata Lv2:
  16.         Codec Configuration:
  17.             Codec ID: [6 (0x06)]
  18.             Codec ID Company ID: [0 (0x0000)]
  19.             Codec ID Vendor ID: [0 (0x0000)]
  20.             Codec Specific Configuration Length: [16 (0x10)]
  21.             Codec Specific Configuration LTV:
  22.                 LTV Wrapper: {
  23.     Length: [2 (0x02)]
  24.     Type and Value:
  25.         Type: [1 (0x01)]
  26.         Value: [0x08],
  27.     Length: [2 (0x02)]
  28.     Type and Value:
  29.         Type: [2 (0x02)]
  30.         Value: [0x01],
  31.     Length: [5 (0x05)]
  32.     Type and Value:
  33.         Type: [3 (0x03)]
  34.         Value: [0x03, 0x00, 0x00, 0x00],
  35.     Length: [3 (0x03)]
  36.     Type and Value:
  37.         Type: [4 (0x04)]
  38.         Value: [0x64, 0x00]}
  39.         Metadata Length: [0 (0x00)]
  40.     BIS Codec Subgroup Lv3: {
  41.     BIS index: [1 (0x01)]
  42.     Codec Specific Configuration Length: [16 (0x10)]
  43.     Codec Specific Configuration LTV:
  44.         LTV Wrapper: {
  45.     Length: [2 (0x02)]
  46.     Type and Value:
  47.         Type: [1 (0x01)]
  48.         Value: [0x08],
  49.     Length: [2 (0x02)]
  50.     Type and Value:
  51.         Type: [2 (0x02)]
  52.         Value: [0x01],
  53.     Length: [5 (0x05)]
  54.     Type and Value:
  55.         Type: [3 (0x03)]
  56.         Value: [0x01, 0x00, 0x00, 0x00],
  57.     Length: [3 (0x03)]
  58.     Type and Value:
  59.         Type: [4 (0x04)]
  60.         Value: [0x64, 0x00]},
  61.     BIS index: [2 (0x02)]
  62.     Codec Specific Configuration Length: [16 (0x10)]
  63.     Codec Specific Configuration LTV:
  64.         LTV Wrapper: {
  65.     Length: [2 (0x02)]
  66.     Type and Value:
  67.         Type: [1 (0x01)]
  68.         Value: [0x08],
  69.     Length: [2 (0x02)]
  70.     Type and Value:
  71.         Type: [2 (0x02)]
  72.         Value: [0x01],
  73.     Length: [5 (0x05)]
  74.     Type and Value:
  75.         Type: [3 (0x03)]
  76.         Value: [0x02, 0x00, 0x00, 0x00],
  77.     Length: [3 (0x03)]
  78.     Type and Value:
  79.         Type: [4 (0x04)]
  80.         Value: [0x64, 0x00]}}}
  81. - Found Front Left Audio Location.
  82. - Received Data: Broadcast Audio Announcements:
  83.     Length: [6 (0x06)]
  84.     AD Type: [22 (0x16)] Service Data AD Data Type
  85.     Broadcast Audio Announcements Service UUID: [6226 (0x1852)] Service UUID
  86.     Broadcast ID: [33029 (0x008105)]
  87. - Received Data: Basic Audio Announcements:
  88.     Length: [67 (0x43)]
  89.     AD Type: [22 (0x16)]
  90.     Basic Audio Announcement Service UUID: [6225 (0x1851)] Service UUID
  91.     Presentation Delay: [80000 (0x013880)]
  92.     Num Subgroups: [1 (0x01)]
  93.     Codec And Metadata Subgroups: {
  94.     Num BIS: [2 (0x02)]
  95.     Codec And Metadata Lv2:
  96.         Codec Configuration:
  97.             Codec ID: [6 (0x06)]
  98.             Codec ID Company ID: [0 (0x0000)]
  99.             Codec ID Vendor ID: [0 (0x0000)]
  100.             Codec Specific Configuration Length: [16 (0x10)]
  101.             Codec Specific Configuration LTV:
  102.                 LTV Wrapper: {
  103.     Length: [2 (0x02)]
  104.     Type and Value:
  105.         Type: [1 (0x01)]
  106.         Value: [0x08],
  107.     Length: [2 (0x02)]
  108.     Type and Value:
  109.         Type: [2 (0x02)]
  110.         Value: [0x01],
  111.     Length: [5 (0x05)]
  112.     Type and Value:
  113.         Type: [3 (0x03)]
  114.         Value: [0x03, 0x00, 0x00, 0x00],
  115.     Length: [3 (0x03)]
  116.     Type and Value:
  117.         Type: [4 (0x04)]
  118.         Value: [0x64, 0x00]}
  119.         Metadata Length: [0 (0x00)]
  120.     BIS Codec Subgroup Lv3: {
  121.     BIS index: [1 (0x01)]
  122.     Codec Specific Configuration Length: [16 (0x10)]
  123.     Codec Specific Configuration LTV:
  124.         LTV Wrapper: {
  125.     Length: [2 (0x02)]
  126.     Type and Value:
  127.         Type: [1 (0x01)]
  128.         Value: [0x08],
  129.     Length: [2 (0x02)]
  130.     Type and Value:
  131.         Type: [2 (0x02)]
  132.         Value: [0x01],
  133.     Length: [5 (0x05)]
  134.     Type and Value:
  135.         Type: [3 (0x03)]
  136.         Value: [0x01, 0x00, 0x00, 0x00],
  137.     Length: [3 (0x03)]
  138.     Type and Value:
  139.         Type: [4 (0x04)]
  140.         Value: [0x64, 0x00]},
  141.     BIS index: [2 (0x02)]
  142.     Codec Specific Configuration Length: [16 (0x10)]
  143.     Codec Specific Configuration LTV:
  144.         LTV Wrapper: {
  145.     Length: [2 (0x02)]
  146.     Type and Value:
  147.         Type: [1 (0x01)]
  148.         Value: [0x08],
  149.     Length: [2 (0x02)]
  150.     Type and Value:
  151.         Type: [2 (0x02)]
  152.         Value: [0x01],
  153.     Length: [5 (0x05)]
  154.     Type and Value:
  155.         Type: [3 (0x03)]
  156.         Value: [0x02, 0x00, 0x00, 0x00],
  157.     Length: [3 (0x03)]
  158.     Type and Value:
  159.         Type: [4 (0x04)]
  160.         Value: [0x64, 0x00]}}}
  161. - Found Front Right Audio Location.
  162.          -Final Verdict: PASS
  163. TMAP/BMS/ASC/BV-01-C finished
复制代码
签到总天数:495天
签到总奖励:12160金币
 楼主| 发表于 2025-4-12 23:17:24 | 显示全部楼层
数据是jbl音箱做广播源的数据
连续签到天数:4天
签到总天数:133天
签到总奖励:1072金币
发表于 2025-4-16 21:18:42 | 显示全部楼层
多谢分享.
签到总天数:59天
签到总奖励:393金币
发表于 2025-4-25 11:38:33 | 显示全部楼层
学习
GMT+8, 2026-4-4 17:24 , Processed in 0.081759 second(s), 13 queries , Gzip On, MemCached On.
