查看: 1392|回复: 0
[嵌入式] BK7259,博通集成WiFi6音视频双Armv8.1-M Cortex-M52单SOC低功耗芯片
签到总天数:480天
签到总奖励:3983金币
发表于 2025-6-9 11:28:17 | 显示全部楼层 |阅读模式
BK7259是一款高度集成的1x1单频段2.4 GHz Wi-Fi 6(802.11b/g/n/ax)和蓝牙低功耗(LE)5.4组合解决方案,
专为需要大量资源和低功耗的应用设计。双Armv8.1-M Cortex-M52单片机和一整套外设的集成,使BK7259成为高
级物联网(IoT)应用的理想选择。
采用先进的设计技术和超低功耗工艺技术,BK7259为具有大可视屏幕、IP视频对讲机、数字相框、AoV IP摄像
头、HMI应用和其他先进物联网应用的智能门锁提供高集成度和最小功耗。
Wi-Fi ®
IEEE 802.11b/g/n/ax 1x1 compliant
20/40 MHz channel bandwidth for 2.4 GHz
Supports downlink Multi-User Multiple-Input Multiple-Output (DL MU-MIMO)
Supports Orthogonal Frequency Division Multiple Access (OFDMA)
Supports Target Wake Time (TWT)
TX and RX Low-Density Parity Check (LDPC) support for extended range
WPA/WPA2/WPA3-Personal support for enhanced security
Supports STA and SoftAP modes
Supports concurrent SoftAP + STA
TX power up to +20 dBm
RX sensitivity -98 dBm
Bluetooth ® Low Energy
Bluetooth Low Energy (LE) 5.4
Supports Bluetooth Low Energy 1 Mbps, 2 Mbps, and long range (125 kbps and 500 kbps)
Supported Bluetooth Low Energy features: LE Audio, Angle of Arrival (AoA) and Angle of Departure (AoD) direction
finding, 2 Mbps, advertising extensions, and long range
Supports an antenna array with up to 16 antennas for precise positioning
Dual Cores
Dual Arm ® v8.1-M Cortex ® -M52 MCUs at up to 480 MHz
Arm Helium TM vector processing enables enhanced DSP and machine learning (ML) processing
Half-, full-, and double-precision floating-point unit (FPU)
Arm TrustZone ® for system-wide security and protection of software investments
PACBTI extension (Pointer Authentication, Branch Target Identification) mitigated SW ROP/JOP attacks
UART flash download
Serial Wire Debug (SWD) interface
UART for debugging
需要规格书、SDK可咨询
GMT+8, 2026-4-4 17:26 , Processed in 0.262398 second(s), 9 queries , Gzip On, MemCached On.
