查看: 136|回复: 6
[QCC3系列] how i can changing the event tone to my custom sound?
发表于 2025-9-20 00:51:12 | 显示全部楼层 |阅读模式
got a qcc3034 bluetooth module,and i want to change the event tone to custom sound instead of stock sound which come with firmware,so does I need to rebuild the firmware or somethings?
many thanks cuz it's my first time
签到总天数:255天
签到总奖励:5908金币
发表于 2025-9-20 21:42:42 | 显示全部楼层
修改tones可以直接用配置工具修改,修改prompt就需要有源代码才行。
 楼主| 发表于 2025-9-22 03:06:33 | 显示全部楼层
thanks you,but i dont have source code,so can i reverse enginnering the xuv firmware? if i cant so i need to write another one ?
签到总天数:586天
签到总奖励:6089金币
发表于 2025-9-22 07:59:04 | 显示全部楼层
如果你板子没有加密,就可以使用默认的代码重新build,然后加入自己的设定
签到总天数:24天
签到总奖励:168金币
发表于 2025-9-23 09:44:01 | 显示全部楼层
现在的耳机软件普遍都会加密的吧
签到总奖励:4金币
发表于 2025-9-23 12:33:01 | 显示全部楼层
thanks
签到总天数:56天
签到总奖励:381金币
发表于 2025-9-23 19:07:28 | 显示全部楼层
加密了就加不了
GMT+8, 2025-10-6 03:35 , Processed in 0.118586 second(s), 20 queries , Gzip On, MemCached On.
