查看: 1447243|回复: 552
[CSR8系列] CSR8670资料大全
 火... [复制链接]
签到总天数:95天
签到总奖励:592金币
发表于 2014-4-26 17:14:03 | 显示全部楼层 |阅读模式
1楼为:Application Notes
包含以下文件:
CS-126248-AN-2 CVC and aptX License Key Testing in Production.pdf
CS-202067-UG-1 Kalimba DSP Architecture 3 User Guide.pdf
CS-204572-AN-2 Lithium Polymer Battery Charger Calibration and Operation for CSR8670.pdf
CS-204573-AN-1 Configuring the Power Supplies on CSR8670.pdf
CS-204574-AN-1 Configuring the Audio Paths on CSR8670.pdf
CS-204575-AN-3 Using Capacitive Touch Sensors on CSR8670.pdf
CS-207808-AN-2 BlueCore Bluetooth-IEEE 802.11 Coexistence Application Note.pdf
CS-209064-DD-2 Firmware Audio API Specification.pdf
CS-217148-AN-3 CSR8670 Production Test Application Note.pdf
CS-218628-AN-2 Using Speech Recognition in CSR Headset Solutions.pdf
CS-219481-AN-2 Firmware Configuration Keys for CSR8670.pdf
CS-221879-AN-4 CSR8600 Hardware Design Guidelines.pdf
CS-223309-AN-2 CSR8600 Series - Bluetooth Power Table.pdf
CS-225130-AN-1 Using Multiple Library Versions in ADKs.pdf
CS-225602-AN-1 Creating private libraries using Kalasm3 toolchain.pdf
CS-227286-AN-1 Digital Microphone Configuration.pdf
CS-227835-AN-2 Writing to Serial Flash from a VM Application.zip
CS-228822-AN-1 PMU Temperature Controlled Charger Current.pdf
CS-237963-AN Debugging pre-compiled libraries.zip
CS-300650-AN-1 Analogue Audio Input with CSR8670 Dev Board (CNS10001v4).pdf
CS-303425-AN-3 I2S Configuration and Code Modification using ADK 2.5.pdf
CS-304871-AN-2 Tuning Crystal Oscillator Parameters on CSR8600.pdf
CS-307510-AN-1 Selection Guide for Serial SRAM Devices.pdf
CS-307584-AN-1 CSR8600系列硬件设计指南.pdf
CS-309871-UG-1 DSP Training slides.pdf
评分
参与人数 10金币 +40 收起 理由
twbin30 + 6 很给力!
btjacka + 6
CHOI + 3 很给力!
feiyong + 2 很给力!
walkerliang + 6 很给力!
pkuzhx + 6 很给力!
夏天的风 + 6 很给力!
蓝牙APP方案 + 3 很给力!
洒出 + 3
qsls -1 赞一个!
查看全部评分
签到总天数:95天
签到总奖励:592金币
 楼主| 发表于 2014-4-26 17:14:14 | 显示全部楼层
2楼为:Development Tools
包含以下文件:
CS-237041-UG-1 CSR8600 Programming Kit Quick Start Guide.pdf
点评
可以下载吗,给你金币  发表于 2015-2-6 15:12
回复 支持 2 反对 1
签到总天数:95天
签到总奖励:592金币
 楼主| 发表于 2014-4-26 17:14:37 | 显示全部楼层
3楼为:Documentation
包含以下文件:
CNS10001v4a-Schematic Prints.pdf
CS-127997-DS-3 CSR8670 BGA Datasheet.pdf
CS-203853-SP-7 CSR8670 BGA Performance Specification.pdf
CS-220610-PS-1 CSR8670 BGA Development Kit Product Brief.pdf
CNS11012v1-Schematic Prints.pdf
CS-204531-DS-3 CSR8670 WLCSP Datasheet.pdf
CS-210603-SP-3 CSR8670 WLCSP Performance Specification.pdf
CS-228225-PS-1 CSR8670 WLCSP Development Kit Product Brief.pdf
回复 支持 1 反对 0
签到总天数:563天
签到总奖励:11531金币
发表于 2014-4-26 17:56:41 | 显示全部楼层
下载来看一看怎 么样
签到总天数:563天
签到总奖励:11531金币
发表于 2014-4-26 17:57:30 | 显示全部楼层
这么多东西啊
签到总天数:563天
签到总奖励:11531金币
发表于 2014-4-26 22:04:09 | 显示全部楼层
资料真的不错的
发表于 2014-4-26 22:37:09 | 显示全部楼层
路过,学习中。。。
签到总天数:563天
签到总奖励:11531金币
发表于 2014-4-27 10:02:46 | 显示全部楼层
资料太好了啊我今天照着改了一下啊
签到总天数:888天
签到总奖励:8532金币
发表于 2014-4-28 23:39:38 | 显示全部楼层
thank you for your share out.
签到总天数:10天
签到总奖励:47金币
发表于 2014-5-2 13:39:33 | 显示全部楼层
这么多资料,全下都不够币...
回复 支持 0 反对 1
GMT+8, 2026-11-19 03:27 , Processed in 0.021632 second(s), 20 queries , Gzip On, Redis On.
