查看: 2626|回复: 0
[供应] IPQ5018/IPQ6010 CPU High Power WIFI6 solution achieve Fast Roaming
发表于 2023-6-2 13:02:16 | 显示全部楼层 |阅读模式
What is Fast Roaming?
Fast roaming is a feature in Wi-Fi networks that allows a wireless client to roam seamlessly between different access points (APs) without experiencing a significant interruption in service. This is achieved by reducing the time it takes for a wireless client to switch from one AP to another.
Traditional Wi-Fi roaming involves a process called a full reassociation, where the wireless client disconnects from the current AP and searches for a new AP to connect to. This process can take several seconds, during which time the client loses its connection to the network.
With fast roaming, the wireless client can quickly and securely switch to a new AP without needing to perform a full reassociation. This is done by using pre-authentication and caching techniques, which allow the client to authenticate with a new AP before it actually connects to it.
Fast roaming is especially useful in environments where seamless mobility is critical, such as in enterprise networks, public hotspots, and Wi-Fi calling applications. It can improve the user experience by reducing latency and minimizing disruptions in network connectivity.
What is the application of fast roaming?
Fast roaming has various applications in Wi-Fi networks, particularly in environments where seamless mobility is crucial. Some common applications of fast roaming include:
1.Enterprise Networks: In large enterprise networks, fast roaming allows employees to move freely between different floors, buildings, or areas without losing connectivity. This is particularly useful in environments where real-time applications, such as voice and video, are used.
2.Public Hotspots: In public hotspots, fast roaming enables users to move between different access points without interruption. This is essential for applications such as video streaming and VoIP calls, which require stable and uninterrupted connections.
3.Wi-Fi Calling: In Wi-Fi calling applications, fast roaming allows users to switch seamlessly between Wi-Fi access points and cellular networks, without experiencing any disruption in the call. This is particularly important in areas with poor cellular coverage.
4.Hospitality: In hotels and resorts, fast roaming provides guests with seamless connectivity throughout the property, regardless of their location. This enhances the guest experience and enables hotel staff to provide personalized services.
Overall, fast roaming improves the user experience by providing seamless and uninterrupted connectivity, regardless of the user's location within the Wi-Fi network.
Hardware
Although fast roaming is a crucial technology for improving seamless Wi-Fi network roaming, efficient seamless roaming requires hardware support. WallysTech's hardware DR5018 DR6018 is an advanced device that can help improve the roaming performance of Wi-Fi networks.
DR5018 WiFi6 Routerboard, which is a high-performance networking device designed to support the latest WiFi6 technology. The DR5018 Routerboard features a powerful Qualcomm IPQ5018 chipset, 2T2R 802.11AX MU-MIMO and OFDMA support,1G Ethernet port, and a QCN9074 WiFi6e card slot, making it ideal for use in demanding network environments.
With its advanced hardware features, the DR5018 Routerboard is capable of providing fast and seamless roaming performance in Wi-Fi networks, allowing users to move between different access points without experiencing any interruptions in service. This makes it an ideal solution for enterprise networks, public hotspots, and other high-density network environments where seamless mobility is critical.
DR5018 is suitable as hardware for fast roaming because it has a range of advanced hardware features that can support efficient seamless roaming. Firstly, it uses the latest WiFi6 technology, supporting features such as MU-MIMO and OFDMA, which can increase network throughput and efficiency, thereby reducing latency and improving network responsiveness. Secondly, the DR5018 Routerboard features a powerful Qualcomm IPQ5018 chipset with faster data transfer speeds and lower power consumption, which can maintain high performance and stability of the network. Additionally, the DR5018 is equipped with a 1G Ethernet port and QCN9074 WiFi card, which can provide faster data transfer speeds and more reliable connectivity.
Overall, the DR5018 has a range of excellent hardware features that can provide efficient seamless roaming performance, making it an ideal hardware device for fast roaming. It is suitable for enterprise networks, public hotspots, and other high-density network environments, providing users with a seamless mobility experience.
DR6018V4 WiFi6 Routerboard, which is a high-performance networking device designed to support the latest WiFi6 technology. The DR6018V4 Routerboard features a powerful Qualcomm IPQ6010/IPQ6018 family chipset, 2T2R 802.11AX MU-MIMO and OFDMA support, a 2.5G Ethernet port, and support for 5G cellular modems.
With its advanced hardware features, the DR6018V4 Routerboard is capable of providing fast and seamless roaming performance in Wi-Fi networks, allowing users to move between different access points without experiencing any interruptions in service. The support for 5G cellular modems enables the DR6018V4 to serve as a backup connection in case of network failures, ensuring seamless connectivity at all times.
DR6018V4 is suitable as hardware for fast roaming due to its advanced hardware features that provide high-performance and reliable Wi-Fi connectivity. Firstly, it uses the latest WiFi6 technology, which supports features such as MU-MIMO and OFDMA that can significantly increase network efficiency and throughput, thereby reducing latency and enhancing network responsiveness. Secondly, the DR6018V4 Routerboard features a powerful Qualcomm IPQ6010/IPQ6018 chipset that can support high-speed data transfer rates and maintain network stability.
Additionally, the DR6018V4 Routerboard includes 2T2R 802.11AX MU-MIMO and OFDMA support, enabling it to provide seamless roaming performance, allowing users to move between different access points without experiencing any service interruptions. It also features a 2.5G Ethernet port, which can provide faster data transfer speeds and support for 5G cellular modems that can act as a backup connection, ensuring continuous connectivity in case of network failures.
Overall, DR6018V4 is a highly reliable and efficient hardware device that can provide fast and seamless roaming performance in Wi-Fi networks. It is an ideal choice for enterprise networks, public hotspots, and other high-density network environments, providing users with uninterrupted and seamless mobility experience.
To learn more about DR5018 and DR6018 and how it can benefit your business, visit our website at https://www.wallystech.com/Routerboard/DR5018-wifi6-Qualcomm-IPQ5018-2T2R-2.5G-ETH-port-802.11AX-MU-MIMO-OFDMA-supporting-QCN9074-wifi-card.html
https://www.wallystech.com/Routerboard/DR6018V4-wifi6-Qualcomm-IPQ6010-IPQ6018-FAMILY-2T2R-2.5G-ETH-port-supporting-5G-celluar-Modem-802-11AX-MU-MIMO-OFDMA.html
Wallys also offer a range of other products and services, including industrial WiFi modules, antennas, and enclosures, as well as customized solutions tailored to your specific needs.
By:sales1@wallystech.com
Website:https://www.wallystech.com/
GMT+8, 2026-9-17 10:35 , Processed in 0.084040 second(s), 12 queries , Gzip On, MemCached On.
