查看: 2802|回复: 0
[供应] Openwrt21.02 Support TDMA Technology for IPQ6010 IPQ4019/IPQ4029 DR40X9 DR6018
发表于 2023-4-25 10:33:39 | 显示全部楼层 |阅读模式
Have you ever experienced slow Wi-Fi speeds, connectivity issues, or interference? Wallys software team may have a solution for you: TDMA technology. TDMA stands for Time Division Multiple Access, which is a method of dividing time into multiple time slots to allow only one device to send or receive data per slot. This technology is being used by Wallys to improve communication efficiency and reliability in Wi-Fi networks.
TDMA technology is particularly useful in Wi-Fi Direct mode or peer-to-peer networking mode, which allows direct communication between devices without relying on traditional access points. In TDMA, time slots are assigned to various devices in a fixed order, enabling multiple devices to communicate on the same frequency without conflicts. Devices can transmit and receive data in different time slots, avoiding collisions and interference, which improves communication efficiency and reliability.
Wallys offers Wi-Fi motherboards that support TDMA technology, including the wifi6 routerboard DR6018 series and the wifi5 router DR40X9. The wifi6 routerboard DR6018 series supports a 6km long-distance test and openwrt21.02, while the wifi5 router DR40X9 supports a 20km long-distance test and has been officially certified by openwrt.
Wallys has three specifications of DR6018 motherboards
1. DR6018
The board has two radios, 2x2 2.4G&5G
1 x 1Gbps Ethernet Ports & POE3 x 1Gbps Ethernet Ports , 1x 2.5Gbps Ethernet Ports
1GB DDRL3L System Memory
32MB NOR Flash, 256MB NAND Flash
1 M.2 slot Support: QUECTEL RM500Q-GL
1 M.2 slot Support: QCN9074 WiFi 6E Card
2. DR6018S
Two radios, 2x2 2.4G&5G
8MB NOR Flash, 256MB NAND Flash
1 x 1Gbps Ethernet Ports & POE 1x 1Gbps Ethernet Ports
3. DR6018C V01
1x SFP port
Wifi5 router DR40X9
It has been officially certified by openwrt and supports the latest openwrt version.
Support 20km long-distance test.
it comes in two versions
1. With SFP
2. Without SFP
Featuring with industrial-grade IPQ4019/IPQ4029 chipsets
Support 4.940GHz to 5.825GHz Frequency Range
Support 2.400GHz to 2.482GHz
Support 2 x 5G MMCX Connectors and 2x2.4G MMCX
Support 5MHz/10MHz/20MHz/40MHz/80MHz Bandwidth
Wallys has several hardware and software technology advantages, including a strong hardware design team, 10 years of software development experience, and the ability to modify and compile software to meet different wifi functional requirements. They have also participated in the openwrt organization and code development. Wallys has worked with notable clients such as TIP, Facebook, and Openwrt.
If you're interested in learning more about TDMA technology or purchasing Wi-Fi motherboards that support TDMA, contact Wallys via email at sales1@wallystech.com or visit their website at https://www.wallystech.com/.
GMT+8, 2026-11-3 09:30 , Processed in 0.027307 second(s), 9 queries , Gzip On, Redis On.
