查看: 54060|回复: 16
[BC5系列] CSR蓝牙模块BC5的I/O口控制
签到总天数:95天
签到总奖励:592金币
发表于 2012-12-29 20:38:12 | 显示全部楼层 |阅读模式
CSR的BC5一共有13个IO口
include pio.h
直接调用'PioSet'函数,设置上1下0拉。
直接调用'PioSetDir'函数,设置输入0输出1
一般输入为弱上拉,直接调用’PioSetStrongBias‘函数,实现强上下拉,1为设置强,0为弱,不代表上下拉
另外还有复用引脚查询,设置
Kalimba用引脚查询,设置
@param mask The bit mask to use.
  @param bits The bits to use.
  This function is used to write the value of the data-output register. Only a
  subset of bits is written, controlled by the value of 'mask'; setting a bit in
  mask allows the corresponding bit in the output register to be changed according
  to the value of the bit in data. Note that bits not set in the mask lead to the
  corresponding output bits being set to the value shown in the data input register
  rather than the value stored in the data output register. i.e.
  \code
  foreach bit
     if mask[bit] is 1
         pioOut[bit] => data[bit]
     else
         pioOut[bit] => pioIn[bit]
  \endcode
  BlueCore (excluding BC01) has internal resistors which can be configured
  to either pull-up or pull-down mode when the pins are used for input. This
  is controlled by the value written to the output register using 'PioSet'.
  The resistors pull-down if the value is zero, and pull-up otherwise, so the
  following fragment sets pins 1 and 2 to inputs with pin 1 configured to
  pull-up and pin 2 configured to pull-down.
  \code
  PioSet(2|4, 2);
  PioSetDir(2|4, 0);
  \endcode
All BlueCore variants (above BC01) include weak internal pull-ups or
  pull-downs on pins which are being used as inputs. If the value set
  in the output register (for a pin which is being used as an input) is
  1, then the internal pull-up is enabled, otherwise the pin is pulled-down.
  On later BlueCore variants (not BC01, BC02-external), the pull-up or
  pull-down can be made stronger by writing a 1 into the corresponding bit
  in the bias register by calling this function.
  So to set pin 4 and 5 as inputs, 4 pulled up weakly, 5 pulled down strongly
  \code
   PioSetDir((1<<4)|(1<<5), 0);
   PioSet((1<<4)|(1<<5), (1<<4));
   PioSetStrongBias((1<<4)|(1<<5), (1<<5));
  \endcode
发表于 2013-1-2 09:51:21 | 显示全部楼层
不错,又占了一个沙发!
签到总天数:7天
签到总奖励:31金币
发表于 2013-1-21 12:08:33 | 显示全部楼层
学习了!感觉不够详细!
签到总天数:7天
签到总奖励:31金币
发表于 2013-1-21 20:16:03 | 显示全部楼层
挣积分,积分!
发表于 2013-4-23 12:55:12 | 显示全部楼层
下来学习学习
发表于 2013-5-27 22:42:23 | 显示全部楼层
学习 学习了
发表于 2013-9-4 23:35:46 | 显示全部楼层
谢谢楼主讲解
发表于 2013-9-8 01:33:30 | 显示全部楼层
使用CSR蓝牙Chip进行Layout PCB注意事项
发表于 2013-10-29 23:22:27 | 显示全部楼层
这个好好学习
发表于 2013-12-9 09:34:28 | 显示全部楼层
谢谢!新手来学习了!
GMT+8, 2026-4-6 17:51 , Processed in 0.092854 second(s), 20 queries , Gzip On, MemCached On.
