查看: 36903|回复: 2
[QCC3系列] BitserialOpen()返回值
签到总奖励:4金币
发表于 2020-7-13 14:49:37 | 显示全部楼层 |阅读模式
static bitserial_handle i2cPioInit(uint16 address){    bitserial_config bsconfig;#if 1    uint32 i;    uint16 bank;    uint16 mask;    struct    {        uint16 pio;        pin_function_id func;    }i2c_pios[] = {{i2cClockPio,BITSERIAL_1_CLOCK_OUT},                   {i2cClockPio,BITSERIAL_1_CLOCK_IN},                   {i2cDataPio,BITSERIAL_1_DATA_OUT},                   {i2cDataPio,BITSERIAL_1_DATA_IN}};
    for (i = 0; i < ARRAY_DIM(i2c_pios); i++)    {        uint16 pio = i2c_pios[i].pio;        bank = PIO2BANK(pio);        mask = PIO2MASK(pio);
        /* Setup I2C PIOs with strong pull-up */        PanicNotZero(PioSetMapPins32Bank(bank, mask, 0));        //PanicFalse(PioSetFunction(pio, i2c_pios.func));        PanicNotZero(PioSetDir32Bank(bank, mask, 0));        PanicNotZero(PioSet32Bank(bank, mask, mask));        PanicNotZero(PioSetStrongBias32Bank(bank, mask, mask));    }#endif    /* Configure Bitserial to work with vncl3020 proximity sensor */    memset(&bsconfig, 0, sizeof(bsconfig));    bsconfig.mode = BITSERIAL_MODE_I2C_MASTER;    bsconfig.clock_frequency_khz = i2cClockKhz;    bsconfig.u.i2c_cfg.i2c_address = address;    bsconfig.timeout_ms = 50;    bsconfig.u.i2c_cfg.flags = BITSERIAL_I2C_ACT_ON_NAK_STOP;    return BitserialOpen((bitserial_block_index)BITSERIAL_BLOCK_1, &bsconfig);
}#endif
I2C 初始化过程中没有建立成功。单步调试BitserialOpen()的handler返回值是1.
签到总天数:125天
签到总奖励:1897金币
发表于 2020-7-13 15:06:28 | 显示全部楼层
你这个代码放的没办法看哦,还不如截图。
签到总奖励:4金币
 楼主| 发表于 2020-8-5 10:51:46 | 显示全部楼层
了解,非常感谢!
GMT+8, 2026-1-28 09:18 , Processed in 0.083980 second(s), 16 queries , Gzip On, MemCached On.
