查看: 9577|回复: 8
[QCC3系列] Help qcc3031 same mac address !!!
签到总天数:5天
签到总奖励:27金币
发表于 2022-8-27 16:30:39 | 显示全部楼层 |阅读模式
I have 4 bluetooth 3031 renaming children that are faulty and can't find their names when powered up. I dumped the fw.xuv of 1 usable one and burned the 4 that were faulty. the other 4 results were found when powered up, but they have the same mac address and still can't be renamed with qcc-tool. There is no way to fix it. Please help me. thanks a lot
签到总天数:5天
签到总奖励:27金币
 楼主| 发表于 2022-8-27 19:16:17 来自手机 | 显示全部楼层
Up help
连续签到天数:7天
签到总天数:299天
签到总奖励:7193金币
发表于 2022-8-28 11:27:00 | 显示全部楼层
可以自己修改蓝牙地址。
签到总天数:5天
签到总奖励:27金币
 楼主| 发表于 2022-8-28 13:28:01 | 显示全部楼层
jjr 发表于 2022-8-28 11:27
可以自己修改蓝牙地址。
Do you have a tutorial on how to change it? I also use MDE WIN build fw it has changed blutooth address but it doesn't have audio output.
签到总天数:707天
签到总奖励:7341金币
发表于 2022-8-29 08:07:06 | 显示全部楼层
nguyentrung2202 发表于 2022-8-28 13:28
Do you have a tutorial on how to change it? I also use MDE WIN build fw it has changed blutooth ad ...
aptx ll还要licsence的,其余解码应该可以任意地址码
签到总天数:5天
签到总奖励:27金币
 楼主| 发表于 2022-8-29 15:34:54 | 显示全部楼层
do you use telegram? I have seen your message but I cannot reply. I have registered qq chat but no success.
签到总天数:5天
签到总奖励:27金币
 楼主| 发表于 2022-8-30 22:48:57 | 显示全部楼层
I built the fw with MDE WIN 2.2.0.68 but adjusted the eq with QACT_v7.2.8 and saw the sbc decoder instead of the original fw it was aac decoder
发表于 2023-5-20 13:55:43 | 显示全部楼层
If you are unable to do it using QCC-Tool then try with ConfigApp. There you would be able to change Bluetooth Address as well as device name.
发表于 2023-5-20 13:57:23 | 显示全部楼层
Try by using ConfigApp. It will do the same work.
GMT+8, 2026-11-3 06:29 , Processed in 0.028205 second(s), 20 queries , Gzip On, Redis On.
