查看: 5019|回复: 13
[QCC3系列] help!!! qcc3031 rename error failed to find anymore
签到总天数:5天
签到总奖励:27金币
发表于 2022-8-19 19:55:12 | 显示全部楼层 |阅读模式
I use the tool to rename the bluetooth 3031, but when I change it, it gives me an error, I unplug the power supply and can't find the bluetooth anymore. Forbidden the computer is still receiving but can't do anything. Can anyone guide me to fix it? sincerely thank
发表于 2022-8-19 20:20:44 | 显示全部楼层
This is the tool's problem, maybe you need to erase the flash, and download the program again,next time you should read the device first, if device'name read successfully, you can change it..
签到总天数:5天
签到总奖励:27金币
 楼主| 发表于 2022-8-19 20:33:38 | 显示全部楼层
terrysmt1984 发表于 2022-8-19 20:20
This is the tool's problem, maybe you need to erase the flash, and download the program again,next t ...
do i have to flash the fw again for 3031? now QCC_Audio_Tool is receiving my 3031 but I can't do anything. Can't rename it either. Can you give specific instructions or do you have a tutorial. thank you
发表于 2022-8-19 21:30:21 | 显示全部楼层
you should flash the fw again.
签到总天数:5天
签到总奖励:27金币
 楼主| 发表于 2022-8-19 22:05:27 | 显示全部楼层
I don't know how to flash fw? can you help me? I also searched fw for 3031 but didn't see any instructions
签到总奖励:10金币
发表于 2022-8-19 23:12:51 | 显示全部楼层
Try "Build" - "Deploy All"
签到总天数:5天
签到总奖励:27金币
 楼主| 发表于 2022-8-20 11:28:47 | 显示全部楼层
Can you give me the Build 3031 file?
签到总天数:5天
签到总奖励:27金币
 楼主| 发表于 2022-8-20 11:49:44 | 显示全部楼层
I delayed all and met this error:
Exception Name: IndexError
Traceback (most recent call last):
  File "C:/qtil/ADK_QCC512X_QCC302X_WIN_6.3.2.36/tools/ubuild/ubuild.py", line 119, in main
    return dep.deploy(proj_parser, dk_parser, parsed_args);
  File "C:\qtil\ADK_QCC512X_QCC302X_WIN_6.3.2.36\tools\ubuild\maker\deploy.py", line 494, in deploy
    return deploy_to_device(proj_parser, dk_parser, parsed_args, build_output_folder);
  File "C:\qtil\ADK_QCC512X_QCC302X_WIN_6.3.2.36\tools\ubuild\maker\deploy.py", line 410, in deploy_to_device
    return deploy_special_deploy_project(parsed_args, build_output_folder);
  File "C:\qtil\ADK_QCC512X_QCC302X_WIN_6.3.2.36\tools\ubuild\maker\deploy.py", line 386, in deploy_special_deploy_project
    return deploy_single_image.main(args);
  File "C:\qtil\ADK_QCC512X_QCC302X_WIN_6.3.2.36\tools\ubuild\maker\deploy_single_image.py", line 140, in main
    nvscmd = NvsCmd(parsed_args.tools_dir, parsed_args.device_uri);
  File "C:\qtil\ADK_QCC512X_QCC302X_WIN_6.3.2.36\tools\ubuild\maker\nvscmd.py", line 21, in __init__
    self._transport, self._port = self._get_transport_port(transport_uri);
  File "C:\qtil\ADK_QCC512X_QCC302X_WIN_6.3.2.36\tools\ubuild\maker\nvscmd.py", line 31, in _get_transport_port
    transport = target_list[1]
IndexError: list index out of range10:48:12: The process "C:\qtil\ADK_QCC512X_QCC302X_WIN_6.3.2.36\tools\python27\python.exe" exited with code 1.
Error while building/deploying project deploy (kit: ADK QCC512X QCC302X WIN 6.3.2.36 - 6.3.2)
When executing step "Using Device"
10:48:12: Elapsed time: 00:52.
签到总天数:5天
签到总奖励:27金币
 楼主| 发表于 2022-8-21 01:41:20 | 显示全部楼层
help me
签到总天数:5天
签到总奖励:27金币
 楼主| 发表于 2022-8-27 15:14:57 | 显示全部楼层
up up
GMT+8, 2026-5-16 06:34 , Processed in 0.141992 second(s), 21 queries , Gzip On, MemCached On.
