楼主: 昆昆昆
[CSR8系列] CSR8670 的问题
签到总天数:10天
签到总奖励:47金币
发表于 2016-6-25 17:59:42 | 显示全部楼层
以下引用8670datasheet描述:
PIO[9]:If interrupts are enabled on VCHG the logic signal is internally routed to PIO[9] to enable CSR8670 BGA to wake up from deep sleep when VCHG is pressed,
PIO8[8]:If interrupts are enabled on VREGENABLE the logic signal is internally routed to PIO[8] to enable CSR8670 BGA to wake up from deep sleep when VREGENABLE is pressed,
签到总天数:202天
签到总奖励:2385金币
发表于 2016-6-27 14:10:13 | 显示全部楼层
PIO[9]:If interrupts are enabled on VCHG the l ...
对!资料里面都有每个PIN,IO的用途都有详细介绍的
签到总天数:493天
签到总奖励:17160金币
发表于 2016-6-29 19:34:52 | 显示全部楼层
签到总天数:987天
签到总奖励:20849金币
发表于 2016-6-30 18:31:15 | 显示全部楼层
GMT+8, 2026-10-26 02:42 , Processed in 0.018283 second(s), 11 queries , Gzip On, Redis On.
