查看: 22871|回复: 10
[CSR8系列] csr8670 cvc handsfree 2 mic
连续签到天数:5天
签到总天数:32天
签到总奖励:388金币
发表于 2016-8-12 00:33:16 | 显示全部楼层 |阅读模式
Hello, i'm testing building sink application using csr8670, audio playing it's ok, but i have some license problems with a new firmwares and ADK versions. I have tested with cvc testing licenses keys for headset and handsfree mic settings:
FW - mic set - ADK version
4.1_27c hands free 2 mic ADK 3.0 --> playing and 2 mic OK
4.2_28a hands free 1 mic ADK 4.0 --> playing ok and 1 mic OK, with 2 mic handsfree testing license key audio muted
4.2_28a1 hands free not work ADK 4.0.1 --> playing ok but 1 mic or 2 mic handsfree, with testing license key audio muted
In the case 1 mic or 2 mic in headset mode all work ok, audio not mutted, the problem is with ADK 4.0 or ADK 4.0.1 for handsfree mode.
Does someone know if are there others testing licenses key or what is the problem?
Thanks!!!
签到总天数:1400天
签到总奖励:45965金币
发表于 2016-8-12 07:49:28 | 显示全部楼层
好深奥的东西,解释一下
签到总天数:676天
签到总奖励:20378金币
发表于 2016-8-12 08:37:21 | 显示全部楼层
楼主肯定想找CSR原厂支持,所以用洋文写~!
我也干过这样的事,但人家跟我说找代理~!
签到总天数:337天
签到总奖励:9829金币
发表于 2016-8-12 09:24:02 | 显示全部楼层
英文挺拽的
看不懂
签到总天数:24天
签到总奖励:119金币
发表于 2016-8-12 10:50:55 | 显示全部楼层
错了,楼主本来非华人。
签到总天数:676天
签到总奖励:20378金币
发表于 2016-8-12 10:56:38 | 显示全部楼层
btspeaker 发表于 2016-8-12 10:50
错了,楼主本来非华人。
那敢情好呀~!既可以和国际友人交流,还可以学外语,多好呀~
我们论坛是国内最好的蓝牙论坛,看来如果叫中国蓝牙网太局限了~!
签到总天数:1113天
签到总奖励:20074金币
发表于 2016-8-12 11:38:35 | 显示全部楼层
Headfree 与 headset 的1mic与2mic使用的license 都是不一样的~
签到总天数:887天
签到总奖励:8528金币
发表于 2016-8-12 12:02:21 | 显示全部楼层
错了,楼主本来非华人。
要学会习惯看英文信息与资料才对!!!!!!!!!!!!!!!!
连续签到天数:5天
签到总天数:32天
签到总奖励:388金币
 楼主| 发表于 2016-8-15 23:24:25 | 显示全部楼层
I'm sorry, it's difficult to explain the problem, basically with ADK 4.0 and adk 4.0.1 handsfree mode and sink app not works well. I'm only asked if anyone has been the same problem. I'd like run the firmware 28 version.
On the other hand, i just want to collaborate and learn, I'm not here to offend anyone, besides all manuals are in English CSR, the company is from Cambridge. English should be accepted here.
Thank you for your help.
连续签到天数:5天
签到总天数:32天
签到总奖励:388金币
 楼主| 发表于 2016-8-21 23:21:02 | 显示全部楼层
Hello,
I solved the problem. There were several lines disabled (with # symbol) in the mak project file. I enabled the lines, compile and works with ADK firmware 4.0.1 and 28a1.
Thank you very much.
GMT+8, 2026-10-22 20:54 , Processed in 0.023164 second(s), 18 queries , Gzip On, Redis On.
