查看: 6094|回复: 7
[CSR8系列] 8670用ADK4.0.0开发TWS
签到总天数:1503天
签到总奖励:26914金币
发表于 2016-9-12 13:50:29 | 显示全部楼层 |阅读模式
各位大神,8670用ADK4.0.0开发TWS下载到板子时提示merge.xpv过大是怎么问题?file:///C:\Users\Administrator\AppData\Roaming\Tencent\Users\312463568\QQ\WinTemp\RichOle\{W%1]M{}W2S6X4M8NUKC~%G.png如下:
D:/ADK4.0.0/tools/bin/remove image/usb_root
D:/ADK4.0.0/tools/bin/remove image/usb_fat
D:/ADK4.0.0/tools/bin/remove image/config/*
headset.mak:269: No voice prompts defined for this application
D:/ADK4.0.0/tools/bin/packfile image image.fs
53 words used to enforce data alignment.
D:/ADK4.0.0/tools/bin/vmbuilder -size 16064 merge.xpv D:/ADK4.0.0/firmware/assisted/unified/gordon/stack_unsigned.xuv image.fs
Filesystem is 6933211 words too large for use with this firmware.
make: *** [merge.xpv] Error 1
Finished.
签到总天数:337天
签到总奖励:9829金币
发表于 2016-9-12 13:59:22 | 显示全部楼层
换一下模式如native 等试试
签到总天数:1503天
签到总奖励:26914金币
 楼主| 发表于 2016-9-12 14:07:20 | 显示全部楼层
yang1 发表于 2016-9-12 13:59
换一下模式如native 等试试
换了native模式又出现这情况了:
D:/ADK4.0.0/tools/bin/xapnative-local-xapnative-gcc-3.3.3 -BD:/ADK4.0.0/tools/lib/gcc-lib/xapnative-local-xapnative/3.3.3\\ -xap2+ -large -mbig-function-pointers -mleaf-optim -munderscore -g -O -fno-builtin-memcpy -ansi -pedantic -Wall -Wmissing-prototypes -Wstrict-prototypes -Wsign-compare -Wredundant-decls -Werror -ID:/ADK4.0.0/tools/include/firmware -ID:/ADK4.0.0/tools/include/standard -ID:/ADK4.0.0/tools/include/profiles/BlueLab-7.0.1-Release -Wp,-MD,./depend/sink_upgrade -Wp,-MQ,sink_upgrade.o -DENABLE_BATTERY_OPERATION -DDEVICE_ID_PSKEY -DGATT_ENABLED -DBLE_ENABLED_WHEN_OFF -DGATT_ANCS_CLIENT -DGATT_IAS_CLIENT -DGATT_BATTERY_SERVER -DGATT_BATTERY_SERVER_PEER -DGATT_IAS_SERVER -DGATT_GAIA_SERVER -DGATT_IAS_SERVER -DGATT_LLS_SERVER -DGATT_TPS_SERVER -DENABLE_CAPSENSE -DENABLE_AVRCP -DINCLUDE_DSP -DINCLUDE_CVC -DTHREE_WAY_CALLING -DINCLUDE_APTX_ACL_SPRINT -DINCLUDE_FASTSTREAM -DENABLE_PEER -DPEER_TWS -DPEER_AVRCP -DENABLE_UPGRADE  -I./ -c sink_upgrade.c -o sink_upgrade.o
D:/ADK4.0.0/tools/bin/xapnative-local-xapnative-gcc-3.3.3 -BD:/ADK4.0.0/tools/lib/gcc-lib/xapnative-local-xapnative/3.3.3\\ -xap2+ -large -mbig-function-pointers -mleaf-optim -munderscore -g -O -fno-builtin-memcpy -ansi -pedantic -Wall -Wmissing-prototypes -Wstrict-prototypes -Wsign-compare -Wredundant-decls -Werror -ID:/ADK4.0.0/tools/include/firmware -ID:/ADK4.0.0/tools/include/standard -ID:/ADK4.0.0/tools/include/profiles/BlueLab-7.0.1-Release -Wp,-MD,./depend/sink_usb -Wp,-MQ,sink_usb.o -DENABLE_BATTERY_OPERATION -DDEVICE_ID_PSKEY -DGATT_ENABLED -DBLE_ENABLED_WHEN_OFF -DGATT_ANCS_CLIENT -DGATT_IAS_CLIENT -DGATT_BATTERY_SERVER -DGATT_BATTERY_SERVER_PEER -DGATT_IAS_SERVER -DGATT_GAIA_SERVER -DGATT_IAS_SERVER -DGATT_LLS_SERVER -DGATT_TPS_SERVER -DENABLE_CAPSENSE -DENABLE_AVRCP -DINCLUDE_DSP -DINCLUDE_CVC -DTHREE_WAY_CALLING -DINCLUDE_APTX_ACL_SPRINT -DINCLUDE_FASTSTREAM -DENABLE_PEER -DPEER_TWS -DPEER_AVRCP -DENABLE_UPGRADE  -I./ -c sink_usb.c -o sink_usb.o
D:/ADK4.0.0/tools/bin/xapnative-local-xapnative-gcc-3.3.3 -BD:/ADK4.0.0/tools/lib/gcc-lib/xapnative-local-xapnative/3.3.3\\ -xap2+ -large -mbig-function-pointers -mleaf-optim -munderscore -g -O -fno-builtin-memcpy -ansi -pedantic -Wall -Wmissing-prototypes -Wstrict-prototypes -Wsign-compare -Wredundant-decls -Werror -ID:/ADK4.0.0/tools/include/firmware -ID:/ADK4.0.0/tools/include/standard -ID:/ADK4.0.0/tools/include/profiles/BlueLab-7.0.1-Release -Wp,-MD,./depend/sink_utils -Wp,-MQ,sink_utils.o -DENABLE_BATTERY_OPERATION -DDEVICE_ID_PSKEY -DGATT_ENABLED -DBLE_ENABLED_WHEN_OFF -DGATT_ANCS_CLIENT -DGATT_IAS_CLIENT -DGATT_BATTERY_SERVER -DGATT_BATTERY_SERVER_PEER -DGATT_IAS_SERVER -DGATT_GAIA_SERVER -DGATT_IAS_SERVER -DGATT_LLS_SERVER -DGATT_TPS_SERVER -DENABLE_CAPSENSE -DENABLE_AVRCP -DINCLUDE_DSP -DINCLUDE_CVC -DTHREE_WAY_CALLING -DINCLUDE_APTX_ACL_SPRINT -DINCLUDE_FASTSTREAM -DENABLE_PEER -DPEER_TWS -DPEER_AVRCP -DENABLE_UPGRADE  -I./ -c sink_utils.c -o sink_utils.o
D:/ADK4.0.0/tools/bin/xapnative-local-xapnative-gcc-3.3.3 -BD:/ADK4.0.0/tools/lib/gcc-lib/xapnative-local-xapnative/3.3.3\\ -xap2+ -large -mbig-function-pointers -mleaf-optim -munderscore -g -O -fno-builtin-memcpy -ansi -pedantic -Wall -Wmissing-prototypes -Wstrict-prototypes -Wsign-compare -Wredundant-decls -Werror -ID:/ADK4.0.0/tools/include/firmware -ID:/ADK4.0.0/tools/include/standard -ID:/ADK4.0.0/tools/include/profiles/BlueLab-7.0.1-Release -Wp,-MD,./depend/sink_volume -Wp,-MQ,sink_volume.o -DENABLE_BATTERY_OPERATION -DDEVICE_ID_PSKEY -DGATT_ENABLED -DBLE_ENABLED_WHEN_OFF -DGATT_ANCS_CLIENT -DGATT_IAS_CLIENT -DGATT_BATTERY_SERVER -DGATT_BATTERY_SERVER_PEER -DGATT_IAS_SERVER -DGATT_GAIA_SERVER -DGATT_IAS_SERVER -DGATT_LLS_SERVER -DGATT_TPS_SERVER -DENABLE_CAPSENSE -DENABLE_AVRCP -DINCLUDE_DSP -DINCLUDE_CVC -DTHREE_WAY_CALLING -DINCLUDE_APTX_ACL_SPRINT -DINCLUDE_FASTSTREAM -DENABLE_PEER -DPEER_TWS -DPEER_AVRCP -DENABLE_UPGRADE  -I./ -c sink_volume.c -o sink_volume.o
D:/ADK4.0.0/tools/bin/xapnative-local-xapnative-gcc-3.3.3 -BD:/ADK4.0.0/tools/lib/gcc-lib/xapnative-local-xapnative/3.3.3\\ -xap2+ -large -mbig-function-pointers -mleaf-optim -munderscore -g -O -fno-builtin-memcpy -ansi -pedantic -Wall -Wmissing-prototypes -Wstrict-prototypes -Wsign-compare -Wredundant-decls -Werror -ID:/ADK4.0.0/tools/include/firmware -ID:/ADK4.0.0/tools/include/standard -ID:/ADK4.0.0/tools/include/profiles/BlueLab-7.0.1-Release -Wp,-MD,./depend/sink_wired -Wp,-MQ,sink_wired.o -DENABLE_BATTERY_OPERATION -DDEVICE_ID_PSKEY -DGATT_ENABLED -DBLE_ENABLED_WHEN_OFF -DGATT_ANCS_CLIENT -DGATT_IAS_CLIENT -DGATT_BATTERY_SERVER -DGATT_BATTERY_SERVER_PEER -DGATT_IAS_SERVER -DGATT_GAIA_SERVER -DGATT_IAS_SERVER -DGATT_LLS_SERVER -DGATT_TPS_SERVER -DENABLE_CAPSENSE -DENABLE_AVRCP -DINCLUDE_DSP -DINCLUDE_CVC -DTHREE_WAY_CALLING -DINCLUDE_APTX_ACL_SPRINT -DINCLUDE_FASTSTREAM -DENABLE_PEER -DPEER_TWS -DPEER_AVRCP -DENABLE_UPGRADE  -I./ -c sink_wired.c -o sink_wired.o
D:/ADK4.0.0/tools/bin/xapnative-local-xapnative-gcc-3.3.3 -BD:/ADK4.0.0/tools/lib/gcc-lib/xapnative-local-xapnative/3.3.3\\ -xap2+ -large -mbig-function-pointers -mleaf-optim -munderscore -g -O -fno-builtin-memcpy  -Xlinker -s0  -ldisplay_plugin_cns10010_scroll -ldisplay_example_plugin -ldisplay -lavrcp -lpower -lconnection -lbdaddr -lhfp_min_cfm -lregion -lservice -lcodec -laudio -lcsr_cvc_common_plugin_all -lcsr_voice_prompts_plugin -lcsr_a2dp_decoder_common_plugin_stereo_bidir -la2dp -lcsr_common_example_plugin -lobex -lsdp_parse -lmd5 -lusb_device_class -lspp_common -lspps -lsppc -lpblock -laudio_plugin_common -lcsr_dut_audio_plugin -lpio_common -lpbapc -lmapc -lfm_rx_plugin -lfm_rx_api -lswat -lcsr_i2s_audio_plugin -lgaia -lgatt -lgatt_imm_alert_client -lgatt_apple_notification_client -lgatt_battery_client -lgatt_device_info_client -lgatt_hid_client -lbyte_utils -lupgrade -lgatt_manager -lgatt_battery_server -lgatt_server -lgatt_gap_server -lgatt_transmit_power_server -lgatt_imm_alert_server -lgatt_link_loss_server -lcsr_multi_channel_plugin -lgatt_client -lgatt_scan_params_client  -Wl,-ID:/ADK4.0.0/tools/lib/gcc-lib/xapnative-local-xapnative/3.3.3/ -Xlinker -pass -Xlinker 250 -LD:/ADK4.0.0/tools/lib/BlueLab-7.0.1-Release/native main.o sink_a2dp.o sink_anc.o sink_at_commands.o sink_audio.o sink_audio_prompts.o sink_audio_routing.o sink_auth.o sink_avrcp.o sink_avrcp_browsing.o sink_avrcp_browsing_channel.o sink_avrcp_qualification.o sink_ble.o sink_ble_advertising.o sink_ble_gap.o sink_ble_scanning.o sink_buttonmanager.o sink_buttons.o sink_callmanager.o sink_config.o sink_configmanager.o sink_csr_features.o sink_device_id.o sink_devicemanager.o sink_display.o sink_dut.o sink_fm.o sink_gaia.o sink_gatt.o sink_gatt_client.o sink_gatt_client_ancs.o sink_gatt_client_battery.o sink_gatt_client_dis.o sink_gatt_client_gatt.o sink_gatt_client_hid.o sink_gatt_client_ias.o sink_gatt_client_spc.o sink_gatt_db.o sink_gatt_hid_remote_control.o sink_gatt_init.o sink_gatt_manager.o sink_gatt_server.o sink_gatt_server_battery.o sink_gatt_server_gap.o sink_gatt_server_gatt.o sink_gatt_server_ias.o sink_gatt_server_lls.o sink_gatt_server_tps.o sink_indicators.o sink_init.o sink_input_manager.o sink_inquiry.o sink_ir_remote_control.o sink_led_manager.o sink_leds.o sink_link_policy.o sink_mapc.o sink_multi_channel.o sink_multipoint.o sink_partymode.o sink_pbap.o sink_peer.o sink_peer_qualification.o sink_pio.o sink_powermanager.o sink_scan.o sink_slc.o sink_speech_recognition.o sink_statemanager.o sink_swat.o sink_tones.o sink_upgrade.o sink_usb.o sink_utils.o sink_volume.o sink_wired.o -o 8670.app
Library libdisplay_plugin_cns10010_scroll.a not found.
make: *** [8670.app] Error 1
Finished.
签到总天数:337天
签到总奖励:9829金币
发表于 2016-9-12 14:12:49 | 显示全部楼层
提示库文件缺失,少了库文件
签到总天数:13天
签到总奖励:115金币
发表于 2016-9-18 21:56:04 | 显示全部楼层
8760芯片比较贵,这款芯片开发资料好像还不错!
签到总天数:173天
签到总奖励:1662金币
发表于 2016-9-19 14:03:23 | 显示全部楼层
CSR8670做TWS效果真的不行!价格也老贵了!
签到总天数:887天
签到总奖励:8528金币
发表于 2016-9-27 10:28:53 | 显示全部楼层
TWS仍然还是一个死胡同
签到总天数:192天
签到总奖励:2137金币
发表于 2016-12-20 14:21:04 | 显示全部楼层
弱弱的问一句,TWS是什么?
GMT+8, 2026-10-22 20:04 , Processed in 0.028136 second(s), 19 queries , Gzip On, Redis On.
