楼主: chuanzi008
[CSR8系列] 小弟是初学者 在网上买一个8645的模组 想diy个蓝牙耳机 有些问题请教
签到总奖励:20金币
 楼主| 发表于 2013-10-10 22:29:20 | 显示全部楼层
dengxindieying 发表于 2013-10-10 19:02
把开发板资料传上来我们看看
直接用他给的这个图可以吗....   还有那个 k4558是什么
签到总奖励:20金币
 楼主| 发表于 2013-10-10 23:14:51 | 显示全部楼层
把开发板资料传上来我们看看
其他的图在一楼更新了
发表于 2013-10-12 16:00:02 | 显示全部楼层
多看看,多上上论坛,资料都有的。
签到总奖励:5金币
发表于 2013-10-18 14:37:22 | 显示全部楼层
Antenna needs good matching to provide good performance.  If you just connect a long wire to the antenna point, matching will be very poor but it still can receive and transmit.  To achieve a reasonable reception, just 28~30mm length wire soldered to the antenna point will be ok.
签到总奖励:20金币
 楼主| 发表于 2013-10-19 07:59:47 | 显示全部楼层
chrischan1911qq 发表于 2013-10-18 14:37
Antenna needs good matching to provide good performance.  If you just connect a long wire to the ant ...
thank you very much
签到总奖励:5金币
发表于 2013-10-19 11:30:48 | 显示全部楼层
On 13th Floor, the K4558 is an operational amplifier.  The function of it is to convert differential audio signals to single-end audio signal.  It is because all Bluetooth modules have differential audio out.
签到总天数:885天
签到总奖励:15306金币
发表于 2013-10-19 11:36:17 | 显示全部楼层
好好学习天天向上
签到总天数:313天
签到总奖励:6060金币
发表于 2019-10-6 20:34:48 | 显示全部楼层
好好学习天天向上
GMT+8, 2026-10-22 21:41 , Processed in 0.019707 second(s), 14 queries , Gzip On, Redis On.
