楼主: herosyfj
[其他] 做蓝牙耳机,需要买哪些测试仪器?
签到总奖励:5金币
发表于 2013-10-18 10:00:49 | 显示全部楼层
Network analyzer is not an easy equipment to use.  You need to have very strong knowledge background of transmission line theory.  Very important is you need to know how to calibrate the port(s) before you do actual measurement.  Otherwise, measurement data is wrong and useless.
签到总天数:2453天
签到总奖励:91744金币
 楼主| 发表于 2013-10-18 10:46:51 | 显示全部楼层
chrischan1911qq 发表于 2013-10-18 10:00
Network analyzer is not an easy equipment to use.  You need to have very strong knowledge background ...
谢谢大侠指点!你的e文好棒!
请问,你对网分熟悉吗?像我们这样的蓝牙耳机研发生产公司,是不是还需要专门的培训?
签到总奖励:5金币
发表于 2013-10-18 11:11:53 | 显示全部楼层
Yes, we have network analyzer up to 9GHz.  We have been using network analyzer for 20 years.  I can say few people know the techniques to use network analyzer correctly.
For typical Bluetooth speaker design, most designs use ready made module.  It is not a must to have network analyzer in design.  50 ohm antenna port matching should be done on the module already.
For the antenna, if you use chip antenna, just follow the design and layout guidelines of the antenna manufacturer will be fine.  If you use printed PIFA antenna on pcb, you better know how to do 3D EM simulation so that you can predict the antenna radiation pattern and gain.
评分
参与人数 1金币 +3 收起 理由
herosyfj + 3 赞一个!
查看全部评分
签到总天数:2453天
签到总奖励:91744金币
 楼主| 发表于 2013-10-18 12:51:42 | 显示全部楼层
chrischan1911qq 发表于 2013-10-18 11:11
Yes, we have network analyzer up to 9GHz.  We have been using network analyzer for 20 years.  I can  ...
这段英文太正典了!非常感谢!记录备用!
我们在调试天线时,能请贵方帮我们调试吗?
您说的芯片天线(chip antenna)指的是陶瓷天线吗?请给推荐下芯片天线。
曲流型天线属于印制PIFA天线(printed PIFA antenna)吗?
请大侠给推荐下3D EM simulation软件。
再次致谢!
签到总奖励:5金币
发表于 2013-10-18 20:10:44 | 显示全部楼层
Most chip antennas are ceramic antennas (陶瓷天线).  There are many suppliers like Antenova, ACX, Rainsun, Fractus, ...  Taiwanese brands are normally cheaper and performance is ok.
PIFA is Printed Inverted-F antenna.  The name came from the shape like a F on the PCB.
I'm not sure what do you mean by 曲流型天线.  I think it is simple PCB antenna in a shape of |_|ˉ|_|ˉ|_|ˉ.  This is not PIFA antenna.  PIFA antenna has better performance than it.
For the past 5 years, we have been using CST Microwave Studio for 3D EM simulation.  It is quite good.  You can even convert the complete PCB layout gerber file to build the 3D structure and add any plastic and metal cabinets to do a more accurate simulation.  If you include more structures, it will take longer time to complete the simulation.
https://www.cst.com/Products/CSTMWS
评分
参与人数 1金币 +3 收起 理由
herosyfj + 3 赞一个!
查看全部评分
签到总天数:2453天
签到总奖励:91744金币
 楼主| 发表于 2013-10-19 10:07:12 | 显示全部楼层
chrischan1911qq 发表于 2013-10-18 20:10
Most chip antennas are ceramic antennas (陶瓷天线).  There are many suppliers like Antenova, ACX, Ra ...
谢谢大侠的指点!
曲流型天线:Meander Line Antennas
I will study "CST Microwave Studio for 3D EM simulation"software.先在网上找个破解版,学习学习。
请教:
目前在蓝牙应用中,我没见到过使用 ceramic antennas的。我手里有一个开发板、两个蓝牙耳机都是用的Meander line antennas。因此,在我司的蓝牙耳机中,我准备用Meander line antennas。
签到总天数:8天
签到总奖励:37金币
发表于 2013-10-19 11:07:22 | 显示全部楼层
看此贴 受益匪浅呐~!~~~ 顶一下
签到总奖励:5金币
发表于 2013-10-19 11:10:36 | 显示全部楼层
About 7 years ago, we developed a Bluetooth headset and we used ceramic chip antenna.  I think why most designs use Meander Line antennas is because it has lower cost.
Classic meander line antenna has good properties such as, small, low profile, simple and cheap.
These nice features make meander line antenna very popular and usable in many aspect of communication systems such as RFID, Bluetooth and WLAN.
Classic meander line antenna has some disadvantages. They have low efficiency, low bandwidth
and can not operate in multi band frequencies.
So, when you do you design with meander line antenna, you should search for more technical papers to understand the theory.  You must know how to calculate and do the simulation.  Here below is quite a good article for your reference.
签到总天数:2453天
签到总奖励:91744金币
 楼主| 发表于 2013-10-19 18:00:45 | 显示全部楼层
chrischan1911qq 发表于 2013-10-19 11:10
About 7 years ago, we developed a Bluetooth headset and we used ceramic chip antenna.  I think why m ...
看完大侠的回帖,受益非浅!谢谢!
学习了!
附图:
发表于 2013-10-26 19:56:12 | 显示全部楼层
学习,学习{:soso_e113:}
GMT+8, 2025-5-29 13:29 , Processed in 0.133178 second(s), 22 queries , Gzip On, MemCached On.
