查看: 12288|回复: 9
[BC5系列] 如何获得远端设备名称?
签到总天数:405天
签到总奖励:3173金币
发表于 2014-5-28 11:14:39 | 显示全部楼层 |阅读模式
签到总天数:885天
签到总奖励:15306金币
发表于 2014-5-28 14:40:21 | 显示全部楼层
签到总天数:104天
签到总奖励:1701金币
发表于 2014-5-28 14:54:10 | 显示全部楼层
profile support
找相应profile里参数
签到总天数:405天
签到总奖励:3173金币
 楼主| 发表于 2014-5-29 08:37:49 | 显示全部楼层
legendflying 发表于 2014-5-28 14:54
profile support
找相应profile里参数
可以具体点吗?是远端名称,不是本地名称哦。谢谢。
签到总天数:104天
签到总奖励:1701金币
发表于 2014-5-29 13:50:54 | 显示全部楼层
bluelab4.1里面的EIR a,可以把附近搜索到的设备名称打印出来
我把main。c文件贴给看看
/* Copyright (C) Cambridge Silicon Radio Limited 2008-2009 */
/* Part of BlueLab 4.1-Release */
#include <stdio.h>
#include <stdlib.h>
#include <connection.h>
#include <panic.h>
#ifdef DEBUG_ENABLED
#   define DEBUG(x) x
#else
#   define DEBUG(x)
#endif
static TaskData task;           /* application task */
/* application local messages */
enum
    APP_INQUIRE = 0,            /* Inquire devices */
    APP_MESSAGE_TOP
/* EIR data types as defined in Bluetooth Assigned Numbers */
#define EIR_UUID16_PART         0x02    /* More 16-bit UUIDs available */
#define EIR_UUID16              0x03    /* Complete list of 16-bit UUIDs */
#define EIR_UUID32_PART         0x04    /* More 32-bit UUIDs available */
#define EIR_UUID32              0x05    /* Complete list of 32-bit UUIDs */
#define EIR_UUID128_PART        0x06    /* More 128-bit UUIDs available */
#define EIR_UUID128             0x07    /* Complete list of 128-bit UUIDs */
#define EIR_NAME_PART           0x08    /* Shortened local name */
#define EIR_NAME                0x09    /* Complete local name */
#define EIR_TXPOWER             0x0a    /* TX Power level */
#define EIR_OOB_COD             0x0d    /* SSP OOB Class of Device */
#define EIR_OOB_C               0x0e    /* SSP OOB Hash C */
#define EIR_OOB_R               0x0f    /* SSP OOB Randomizer R */
#define EIR_ID                  0x10    /* Device ID */
#define EIR_MANUFACTURER        0xff    /* Manufacturer Specific Data */
static const char *hex = "0123456789abcdef";
static uint8 *bd_format(const bdaddr *addr)
    /* this uses 18 bytes globals but is OK for this example */
    static uint8 rc[18];
    /* return Bluetooth address in human readable format */
    rc[ 0] = hex[(addr->nap >> 12) & 0xf];
    rc[ 1] = hex[(addr->nap >>  8) & 0xf];
    rc[ 3] = hex[(addr->nap >>  4) & 0xf];
    rc[ 4] = hex[(addr->nap >>  0) & 0xf];
    rc[ 6] = hex[(addr->uap >>  4) & 0xf];
    rc[ 7] = hex[(addr->uap >>  0) & 0xf];
    rc[ 9] = hex[(addr->lap >> 24) & 0xf];
    rc[10] = hex[(addr->lap >> 16) & 0xf];
    rc[12] = hex[(addr->lap >> 12) & 0xf];
    rc[13] = hex[(addr->lap >>  8) & 0xf];
    rc[15] = hex[(addr->lap >>  4) & 0xf];
    rc[16] = hex[(addr->lap >>  0) & 0xf];
    rc[2] = rc[5] = rc[8] = rc[11] = rc[14] = ':';
    rc[17] = 0;
    return rc;
static void parse_eir(const uint8 *eir_data, uint8 *endp)
    const char *footer[] = { "...", "" };
    const uint8 *p;
    uint16 i;
    for (p = eir_data; p < endp && p[0]; p += 1 + p[0])
        switch (p[1])
        case EIR_NAME_PART:
        case EIR_NAME:
            printf("    EIR name       ");
            for (i = 1; i < p[0]; i++)
                printf("%c", p[1 + i]);
            printf("%s\n", footer[p[1] - EIR_NAME_PART]);
            break;
        case EIR_TXPOWER:
            printf("    EIR TX power   %d\n", p[2]);
            break;
        default:
            printf("    Unhandled EIR data type %x\n", p[1]);
            break;
static void app_handler(Task task, MessageId id, Message message)
    switch (id)
    case APP_INQUIRE:
        ConnectionInquire(task, 0x9e8b33, 10, 8, 0);
        break;
    case CL_INIT_CFM:
        if (((CL_INIT_CFM_T*)message)->status != success)
            Panic();
        /* set inquiry mode to Inquiry with EIR */
        ConnectionWriteInquiryMode(task, inquiry_mode_eir);
        break;
    case CL_DM_INQUIRE_RESULT:
        CL_DM_INQUIRE_RESULT_T *inq = (CL_DM_INQUIRE_RESULT_T*)message;
        switch (inq->status)
        case inquiry_status_ready:
            /* inquiry completed, start new round after 1 second */
            MessageSendLater(task, APP_INQUIRE, NULL, 1000);
            break;
        case inquiry_status_result:
            printf("%s, RSSI %d\n", bd_format(&inq->bd_addr), inq->rssi);
            /* Extended Inquiry Response data available, print it */
            if (inq->size_eir_data)
                parse_eir(inq->eir_data, inq->eir_data + inq->size_eir_data);
            break;
        } /* switch (inq->status) */
        break;
    case CL_DM_WRITE_INQUIRY_MODE_CFM:
        if (((CL_DM_WRITE_INQUIRY_MODE_CFM_T*)message)->status != success)
            Panic();
        /* Send internal message to start an inquiry */
        MessageSend(task, APP_INQUIRE, NULL);
        break;
    default:
        DEBUG(printf("Unhandled message 0x%x\n", id));
int main(void)
    /* Setup application task */
    task.handler = app_handler;
    /* Initialise Connection handler */
    ConnectionInit(&task);
    MessageLoop();
    return 0;
/* End-of-File */
签到总天数:104天
签到总奖励:1701金币
发表于 2014-5-29 13:51:16 | 显示全部楼层
供参考
签到总天数:405天
签到总奖励:3173金币
 楼主| 发表于 2014-5-29 14:35:42 | 显示全部楼层
OK,谢谢。
签到总天数:45天
签到总奖励:414金币
发表于 2015-1-12 11:50:58 | 显示全部楼层
非常感谢五楼
签到总天数:45天
签到总奖励:414金币
发表于 2015-1-14 11:51:36 | 显示全部楼层
(ADK3.0 CSR8670)但是我跟踪得到 size_eir_data 为 0,eir_data【】也为空,为什么?
签到总天数:45天
签到总奖励:414金币
发表于 2015-1-16 15:45:49 | 显示全部楼层
问高手得到了答案
调用函数: ConnectionReadRemoteName
GMT+8, 2025-5-25 13:00 , Processed in 1.039930 second(s), 24 queries , Gzip On, MemCached On.
