查看: 21738|回复: 3
[其他] [讨论] 关于CSR8670编程中ConnectionInitEx2函数的一些问题
发表于 2014-7-11 18:12:28 | 显示全部楼层 |阅读模式
本人新手,刚刚开始接触CSR8670系列的东西。从IDE到编程方式各种不懂。这两天刚刚到了一块开发板,抱着先改个程序玩玩儿的心态,改了一小段代码,然后就受了无比大的打击。。
我在程序中用了ConnectionInitEx2这个函数,根据ADK中给出的API手册查出了头文件也加上了,编译也通过了,就是在链接的时候报了一个错误:
ld: Undefined symbols:
$_ConnectionInitEx2
没有符号链接,,,没有,,,没有,,,没有符号链接,,为啥呢,,,?
求各路大神解答。新手感激不尽!!!!
代码如下:
#include <connection.h>#include <stdio.h>
#include <print.h>
#include <message_.h>
#include <boot.h>
#include "sink_debug.h"
#include "sink_private.h"
/* Single instance of the device state */
hsTaskData g_stTheSink;
extern void _init(void);
NAME
    app_handler
DESCRIPTION
    This is the main message handler for the Sink Application.  All
    messages pass through this handler to the subsequent handlers.
RETURNS
        VOID
static void app_handler(Task task, MessageId id, Message message)
        DEBUG(("app_handler [%s]\n", __TIME__));
        return;
NAME
    app_handler
DESCRIPTION
    Time critical initialisation
RETURNS
        VOID
void _init(void)
    DEBUG(("_init [%s]\n", __TIME__));
    g_stTheSink.task.handler = app_handler;
    return;
NAME
    main
DESCRIPTION
    The Sink Application starts here...
RETURNS
        int
int main(void)
        uint16 usBootMode;
    DEBUG(("Main [%s]\n", __TIME__));
        usBootMode = BootGetMode();
        switch (usBootMode)
#ifdef CVC_PRODTEST
        case BOOTMODE_CVC_PRODTEST:
            /*run the cvc prod test code and dont start the applicaiton */
            cvcProductionTestEnter() ;
        break ;
#endif
        case BOOTMODE_DFU:
            /*do nothing special for the DFU boot mode,
            This mode expects to have the appropriate host interfface enabled
            Don't start the application */
        break ;
        case BOOTMODE_DEFAULT:
        case BOOTMODE_CUSTOM:
        case BOOTMODE_USB_LOW_POWER:
        case BOOTMODE_ALT_FSTAB:
        default:
            /*the above are application boot modes so kick of the app init routines*/
            const msg_filter usMsgFilter = msg_group_acl;
            uint16 usPdlNumberOfDevices = 1;
            /* the number of paired devices can be restricted using pskey user 40,
               a number between 1 and 8 is allowed
            PsRetrieve(PSKEY_PAIRED_DEVICE_LIST_SIZE, &usPdlNumberOfDevices , sizeof(uint16));*/
            DEBUG (("PDLSize[%d]\n" , usPdlNumberOfDevices));
            /* Initialise the Connection Library with the options */
            ConnectionInitEx2(&g_stTheSink.task, &usMsgFilter, usPdlNumberOfDevices );
        break;
        /* Start the message scheduler loop */
    MessageLoop();
    /* You never get here... */
    return 0;
连续签到天数:4天
签到总天数:3858天
签到总奖励:137398金币
发表于 2014-7-12 10:06:43 | 显示全部楼层
记得加库文件
 楼主| 发表于 2014-7-12 15:06:08 | 显示全部楼层
恩,,谢谢,请问这个库文件应该怎么加呢?因为刚刚接触ADK这套IDE,找不到库文件在哪里加。
发表于 2014-8-3 18:01:25 | 显示全部楼层
突然觉得楼主说的很有道理,赞一个!
GMT+8, 2026-5-7 20:06 , Processed in 0.088682 second(s), 17 queries , Gzip On, MemCached On.
