查看: 29735|回复: 3
[CSR8系列] 自带的sink烧录到csr8670中后报错,请各大侠帮忙看看
签到总天数:40天
签到总奖励:296金币
发表于 2014-8-2 11:42:21 | 显示全部楼层 |阅读模式
F5烧录结束后出现如下log,然后就一直在 LedsIndicateError ( const uint16 errId )中转悠,不知啥原因?
Initialising execution environment for project 'kalimba - 'faststream_decoder''
Kal: Transport is: SPITRANS=USB SPIPORT=0
Kal: Attaching to a gordon
Kal: Using symbol info previously loaded from 'C:/ADK3.0/kalimba/apps/a2dp_sink/faststream_decoder.elf'...
Kal: Loaded memory map: 'C:/ADK3.0/xide/bin/../config/kalimba/gordon.map'
Kal: Loaded kalimba/gordon_peripherals.xml
The VM cannot run, as it is already running.
签到总天数:885天
签到总奖励:15306金币
发表于 2014-8-2 14:31:12 | 显示全部楼层
签到总天数:3天
签到总奖励:19金币
发表于 2014-8-22 10:28:17 | 显示全部楼层
我也遇到这个问题了,楼主解决了吗
签到总天数:3天
签到总奖励:19金币
发表于 2014-8-23 08:42:49 | 显示全部楼层
问题解决了,先擦除pskey,然后烧入adk中带的psr文件 就可以解决
GMT+8, 2026-10-22 19:55 , Processed in 0.030411 second(s), 12 queries , Gzip On, Redis On.
