查看: 10605|回复: 2
[CSR8系列] CSR 8645 - power on problem
发表于 2017-12-31 21:17:43 | 显示全部楼层 |阅读模式
Hello all,
first, sorry that I am writing in english I hope it isnt a big problem
I made schematic and board with using CSR8645 module on it, but I cant turn it on
When I press button ON/OFF it doenst do anything. When I hold button ON/OFF it enters a pairing mode and when I release that button it power off itself. I am using this pskey: [url=]Dump.doc[/url].
Can somebody help me to solve this problem, pleas? I am trying everything but nothing works. I feel lost.
Thanks for any help, suggestions, etc.
连续签到天数:26天
签到总天数:830天
签到总奖励:33308金币
发表于 2018-1-1 00:23:02 | 显示全部楼层
it more likely that you have wrong configuration on Power Button.
Some hardware design use slide switch for Power On/Off, which requires the VREG to be hold to high on On state and low to Off state.
发表于 2018-1-4 11:27:01 | 显示全部楼层
you must download the corresponding .psr file use PSTool firstly,then use config tool configuration the powerkey event
GMT+8, 2026-10-26 17:39 , Processed in 0.045348 second(s), 15 queries , Gzip On, Redis On.
