楼主: littlefish
[ADK相关资料] 使用ADK3.0的xIDE的工具向CSR8670芯片烧录程序出错?
签到总天数:214天
签到总奖励:1390金币
发表于 2014-11-27 14:20:09 | 显示全部楼层
Beukers 发表于 2014-11-26 22:32
你是不是没有download PSR文件到8670里面?
打开PSTool,File -> Merge, 将ADK3.0安装目录下,apps -> Sin ...
ADK3.5  8670 使用Blue Flash完全擦除后,用PSTOOL是连接不上的吧,必须先用xide跑一遍程序。然后才能再用PSTOOL去 merge system 文件。
签到总天数:6天
签到总奖励:36金币
发表于 2014-11-27 15:38:31 | 显示全部楼层
深圳达力欧电子有限公司,专业蓝牙音箱、耳机产品PCBA主板生产加工,欢迎联系洽谈;
联系方式:18603061446陈生  QQ3082236141
地址:深圳横岗街道横坪路87号祥达利科技园A2栋2楼
网站:http://www.smtgo.com/
http://shop1411462622827.1688.com/
http://szdaliou.1688.com/
回复 支持 0 反对 1
签到总天数:2697天
签到总奖励:38930金币
 楼主| 发表于 2014-11-28 08:12:52 | 显示全部楼层
xiayelianqu 发表于 2014-11-27 14:20
ADK3.5  8670 使用Blue Flash完全擦除后,用PSTOOL是连接不上的吧,必须先用xide跑一遍程序。然后才能再 ...
额。。。。我用的是ADK3.0。。。貌似没有出现这种问题。。。
签到总天数:325天
签到总奖励:2455金币
发表于 2014-11-28 09:04:42 | 显示全部楼层
现在正在研究
签到总天数:1296天
签到总奖励:27533金币
发表于 2014-11-30 05:49:49 | 显示全部楼层
you will find that the init() which is call befor main() is the root of your problem, diskable it and your code will run!
签到总天数:1296天
签到总奖励:27533金币
发表于 2014-11-30 05:56:16 | 显示全部楼层
if the configin the init() failes the 8670 goes into a stall, disabling the init() ro renaming it an calling it from main() will get you pass that point. you can also set a break point on init () and trace it for the error.
签到总天数:2697天
签到总奖励:38930金币
 楼主| 发表于 2014-11-30 10:11:02 | 显示全部楼层
Nicked 发表于 2014-11-30 05:56
if the configin the init() failes the 8670 goes into a stall, disabling the init() ro renaming it an ...
。。。请说国语。。。
签到总天数:1296天
签到总奖励:27533金币
发表于 2014-11-30 21:29:34 | 显示全部楼层
littlefish 发表于 2014-11-30 10:11
。。。请说国语。。。
If I tried to speak Mandrain you could not understand anything I have to say. Even thought I dont speak Chinese 1 have over 10 sucessful Bluetooth projects to my name.
签到总天数:2697天
签到总奖励:38930金币
 楼主| 发表于 2014-12-1 08:00:50 | 显示全部楼层
Nicked 发表于 2014-11-30 21:29
If I tried to speak Mandrain you could not understand anything I have to say. Even thought I dont  ...
。。。you can read Chinese,but can't speak Chinese? are you not Chinese?
签到总天数:67天
签到总奖励:479金币
发表于 2014-12-1 09:26:05 | 显示全部楼层
好好学习,天天向上。。。
GMT+8, 2026-10-25 23:19 , Processed in 0.028383 second(s), 17 queries , Gzip On, Redis On.
