查看: 17965|回复: 1
[TI] TI BLE SensorTag中传感器事件是如何触发的?
连续签到天数:4天
签到总天数:122天
签到总奖励:3780金币
发表于 2014-11-25 18:08:11 | 显示全部楼层 |阅读模式
哪位大侠能否告诉我TI  BLE SensorTag中传感器事件是如何触发的? 程序如下:uint16 SensorTag_ProcessEvent( uint8 task_id, uint16 events )
  VOID task_id; // OSAL required parameter that isn't used in this function
// events = events|ST_GYROSCOPE_SENSOR_EVT;
  if ( events & SYS_EVENT_MSG )
    uint8 *pMsg;
    if ( (pMsg = osal_msg_receive( sensorTag_TaskID )) != NULL )
      sensorTag_ProcessOSALMsg( (osal_event_hdr_t *)pMsg );
      // Release the OSAL message
      VOID osal_msg_deallocate( pMsg );
    // return unprocessed events
    return (events ^ SYS_EVENT_MSG);
  // Handle system reset (long press on side key)
  if ( events & ST_SYS_RESET_EVT )
    if (sysResetRequest)
      HAL_SYSTEM_RESET();
    return ( events ^ ST_SYS_RESET_EVT );
  if ( events & ST_START_DEVICE_EVT )
    // Start the Device
    VOID GAPRole_StartDevice( &sensorTag_PeripheralCBs );
    // Start Bond Manager
    VOID GAPBondMgr_Register( &sensorTag_BondMgrCBs );
    return ( events ^ ST_START_DEVICE_EVT );
  //    Accelerometer     //
  if ( events & ST_ACCELEROMETER_SENSOR_EVT ) // ST_ACCELEROMETER_SENSOR_EVT  是如何触发的?是定时器还是profile callback 设置的?
    if(accEnabled)
连续签到天数:4天
签到总天数:122天
签到总奖励:3780金币
 楼主| 发表于 2014-11-28 06:51:07 | 显示全部楼层
看着发帖出来好几天了没有回复,心中感到惆怅,这么多高手没有出手相救的,好在我早起晚归花了3天时间搞明白了,心中冒油样顺畅了很多,想要搞明白的事只要肯花功夫还是会收获的。
GMT+8, 2026-10-22 19:32 , Processed in 0.050542 second(s), 11 queries , Gzip On, Redis On.
