查看: 12725|回复: 4
[CSR8系列] 有没有人写一个8670的流程啊,比如只加载SINK的程序
签到总天数:93天
签到总奖励:622金币
发表于 2015-4-23 11:49:48 | 显示全部楼层 |阅读模式
签到总天数:2419天
签到总奖励:64952金币
发表于 2015-4-23 12:05:16 | 显示全部楼层
ADKSinkUserGuide.pdf里面有说明
2. Getting Started
2.1. To Flash the Audio Sink Application onto Suitable Hardware
1. Connect the interface board to the development board and attach the SPI interface and USB charger.
2. Attach suitable headphones and microphone to the sockets on the development board.
3. Open the xIDE development environment from the ADK program folder.
4. Select Open Workspace from the Project menu and select the sink application from the apps subdirectory.
5. By default the application is setup to run on CSR8670 or CSR8675 hardware, to change hardware or
audio mode, see section 2.
6. Make sure the Transport is set correctly. Choose Debug > Transport and select the required Debug
Transport.
7. Use PSTool to merge the relevant PS Keys onto the device, for basic operation, for:
 CNS10001v4 development board: Use sink_system_csr8670.psr and
sink_config_10001v4_stereo.psr.
 H13179 with H13374 modules : Use sink_system_csr8675.psr and
sink_config_H13179v2_H13374v2_stereo.psr.
签到总天数:24天
签到总奖励:119金币
发表于 2015-4-23 12:59:12 | 显示全部楼层
签到总天数:93天
签到总奖励:622金币
 楼主| 发表于 2015-4-23 15:08:02 | 显示全部楼层
按上面的步骤导入后,发现只要断开SPI连接,蓝牙就会自动关机,是咋回事?
签到总天数:765天
签到总奖励:7275金币
发表于 2016-11-9 18:41:55 | 显示全部楼层
用blueflash down 进去再merge psr即可。
GMT+8, 2026-10-23 00:34 , Processed in 0.062996 second(s), 14 queries , Gzip On, Redis On.
