查看: 22495|回复: 7
[CSR8系列] CSR8675 i2s output freq config
签到总天数:59天
签到总奖励:769金币
发表于 2019-10-1 23:58:54 | 显示全部楼层 |阅读模式
Hello, friends! Where can I find parameters for changing the output frequency of i2s (pstool or sink config tool 4.1)?
I have an i2s output of 96 kHz, I need 44.1 kHz.
chip model csr8675
thanks!
upd. sorry for autotranslate (
签到总天数:59天
签到总奖励:769金币
 楼主| 发表于 2019-10-2 12:33:18 | 显示全部楼层
you can answer in chinese. i'll try to translate
签到总天数:423天
签到总奖励:10866金币
发表于 2019-10-2 22:07:48 | 显示全部楼层
回帖奖励 +100 金币
maybe here ?
0x01da PSKEY_DIGITAL_AUDIO_RATE
Digital Audio Interface override for port clock rate
When acting as a master on the Digital Audio Interface, typically using I2S or DSP mode, this PSKey allows you to define the exact clock rate generated, specified in Hz.
If set to zero, BlueCore calculates the clock rate based on the sample rate and bits per sample.
签到总天数:59天
签到总奖励:769金币
 楼主| 发表于 2019-10-3 00:09:14 | 显示全部楼层
i think its final clock rate = sample rate * bits per sample * 2 chanel.
in this formula i need to change sample rate
but i'll try
upd. no changes (((
签到总天数:2419天
签到总奖励:64952金币
发表于 2019-10-3 23:01:48 | 显示全部楼层
hi
i think you can use config tool not pstool
thanks
签到总天数:2419天
签到总奖励:64952金币
发表于 2019-10-3 23:02:37 | 显示全部楼层
On National Day of China, everyone is on holiday.
签到总天数:59天
签到总奖励:769金币
 楼主| 发表于 2019-10-8 21:10:06 | 显示全部楼层
can someone have other solutions to the problem?
签到总天数:705天
签到总奖励:7333金币
发表于 2019-10-9 08:11:03 | 显示全部楼层
GMT+8, 2026-10-23 04:55 , Processed in 0.024108 second(s), 17 queries , Gzip On, Redis On.
