查看: 55494|回复: 4
[QCC3系列] QCC303x dual I2S output possible?
签到总天数:36天
签到总奖励:228金币
发表于 2020-11-12 18:00:31 | 显示全部楼层 |阅读模式
Hi everyone,
Has anyone managed to enable separated dual I2S outputs?
Single I2S output is OK, but I need dual output to drive 2 separate amplifiers.
The datasheet of the QCC3031 says that the chip can do 3 separate I2S outputs (7.1 Audio subsystem features), but I have not seen anyone doing this.
Can anyone help me with this issue? How would I set this up in the ADK for dual I2S? And will it be possible to adjust both I2S settings in the configuration tool?
My main goal is to be able to drive two I2S amplifiers with separate DSP settings, hence I need two separate I2S outputs.
Sorry for english, and thank you.
签到总天数:128天
签到总奖励:1911金币
发表于 2020-11-12 19:29:47 | 显示全部楼层
没啥意义啊,一路I2S输出可以接2个功放啊,
签到总天数:36天
签到总奖励:228金币
 楼主| 发表于 2020-11-18 19:45:07 | 显示全部楼层
Not if you want separate DSP settings. I want to be able to have stereo speaker with woofer and tweeter. Therefore I need 4 channel DSP allocation. I need I2S for both primary and secondary outputs in DSP.
签到总天数:75天
签到总奖励:2866金币
发表于 2021-7-25 20:28:07 | 显示全部楼层
路过,瞧瞧。
签到总天数:253天
签到总奖励:2463金币
发表于 2021-7-28 10:13:23 | 显示全部楼层
关于明天的事,我们后天就知道了。
GMT+8, 2026-11-3 07:23 , Processed in 0.027122 second(s), 14 queries , Gzip On, Redis On.
