查看: 44905|回复: 0
[供应] CS4344/CS4345/CS4358凌云DAC,10-Pin, 24-Bit, 192 kHz Stereo D/A Converter
签到总天数:6天
签到总奖励:30金币
发表于 2020-11-21 10:21:49 | 显示全部楼层 |阅读模式
CS4344
CS4345
CS4348
CS4344/45/48 产品数据表
单个 3.3 V 或 5.0 V 供电 单端输出 10 引脚 24 位 192 kHz 立体声数/模转换器
CS4344 立体声音频数模转换器 (DAC) 系列可使用单个 +3.3 V 或 +5 V 电源,仅需要最小的支持电路。该系列线性模拟低通滤波器和自动速度模式检测,当自动选择 2 kHz 和 200 kHz 之间的采样率,使用采样率和主时钟速率方法。
Features
t Multi-bit Delta-Sigma Modulator
t 24-bit Conversion
t Automatically Detects Sample Rates up to
192 kHz.
t 105 dB Dynamic Range
t -90 dB THD+N
t Low Clock-Jitter Sensitivity
t Single +3.3 or +5 V Power Supply
t Filtered Line-Level Outputs
t On-chip Digital De-emphasis
t Popguard Technology
t Small 10-pin TSSOP Package
Description
The CS4344 family members (CS4344, CS4345, and
CS4348) are complete, stereo digital-to-analog output
systems including interpolation, multibit D/A conversion
and output analog filtering in a 10-pin package. The
CS4344 family supports major audio data interface formats. Individual devices differ only in the supported
interface format.
The CS4344 family is based on a fourth-order multibit
delta-sigma modulator with a linear analog low-pass filter. This family also includes autospeed mode detection
using both sample rate and master clock ratio as a
method of auto-selecting sampling rates between 2 kHz
and 200 kHz.
The CS4344 family contains on-chip digital deemphasis, operates from a single +3.3 V or +5 V power supply,
and requires minimal support circuitry. These features
are ideal for DVD players & recorders, digital televisions, home theater and set top box products, and
automotive audio systems.
The CS4344 family is available in a 10-pin TSSOP
package in both Commercial (-10 to +85 °C) and Automotive grades (-40 to +85 °C). See Section 8. “Ordering
Information” on page 23 for complete details.
PCM
Serial
Interface
Multibit
DS Modulator
Interpolation
Filter
Internal
Voltage
Reference
Switched
Capacitor
DAC and
Filter
Serial Audio
Input
Right
Output
Left
Output
Switched
Capacitor
DAC and
Filter
De-emphasis
Multibit
DS Modulator
Interpolation
Filter
3.3 V or 5 V
JUL ‘13
DS613F2
GMT+8, 2026-10-22 21:46 , Processed in 0.026896 second(s), 10 queries , Gzip On, Redis On.
