查看: 47545|回复: 0
[供应] SP1229HN大电流车充5V4.8A双路2.4A,宽电压输入同步降压芯片
发表于 2021-7-12 14:59:59 | 显示全部楼层 |阅读模式
电压输入范围:9~40V ,输出电压精度(Vref=1.0V):±2.0% 。
CC/CV 模式,通过外部电阻精确设置限流点;限流精度:±5% 。
过温保护(OTP) ,内置软启动时间:3ms ,固定频率:120KHz 。
输入欠压保护(典型 7.5V) l 占空比范围:0~95% ,COMP 引脚同时实现外部补偿和关断控制,输出可使用陶瓷电容,可调整的输出线缆压降补偿,QFN20L-5×5 封装。
[url=https://www.eechina.com/data/attachment/album/202107/12/115830ztok28amcpo66xa6.png%22+target=%22_blank][/url]
DC-DC大电流降压车充芯片:SP6816F,SP1701F,SP1081F,SP1082F,SP1088F,SP1220F,SP1225F,SP1221F,SP1231FL,SP1233FL,SP1236HF,SP1232F,SP1237F,SP1238F,SP1239EF,SP1289EF,SP1253HN,SP1250HN,SP1257HN,SP1229HN,SP1259HN。
AC-DC副边6级能效恒压系列:SP6660,SP6620HP,SP6650,SP6669P,SP6666,SP6648HF,SP6638HF,SP6649HF,SP6639HF,SP6649DF。
AC-DC原边控制恒压/恒流系列:SP5710,SP5713,SP5715,SP5717,SP5718。
AC-DC原边控制6级能效恒压恒流:SP2689F,SP2689AFB,SP2639F,SP2638F,SP2637F,SP2607F,SP2637AF,SP2635F,SP2650,SP2659F,SP2657F,SP2658F,SP2655F,SP2670,SP2679F,SP2678F,SP2675F,SP2699P,SP2698F,SP2695F,SP2695AF,SP2698AF,SP2731F,SP2738DF,SP2739P。
AC-DC同步整流系列产品:SP6500,SP6501FL,SP6505FL,SP6502FL,SP6503FL,SP6551FL,SP6552FL,SP6553FL,SP6566AFB,SP6566AFC,SP6568AFB,SP6534F,SP6534FB,SP6534FC,SP6506FC,SP6507F,SP6508F,SP6550,SP6530,SP6510,SP6536F,SP6536FB,SP6536FC,SP6516,SP6538F,SP6538FB,SP6538FC,SP6539F,SP6519F,SP6514F,SP6514FB,SP6518F,SP6518FB。
GMT+8, 2026-10-22 19:59 , Processed in 0.024116 second(s), 10 queries , Gzip On, Redis On.
