查看: 2130|回复: 2
[其他] Wallys /QCA9880 vs QCA9882/802.11ac Solution/MU-MIMO
签到总天数:8天
签到总奖励:36金币
发表于 2022-9-20 13:25:00 | 显示全部楼层 |阅读模式
MT7915/MT7975/IPQ6000/IPQ6018/IPQ6010/IPQ4019/IPQ4029/ipq4018/IPQ4028/IPQ8072/IPQ8072A/IPQ8074/IPQ8074A/QCN6024/QCN9074/QCN9072/QCN9024/IPQ5018/AR9223/QCA9880/QCA9882 /AR9582/AR9531/AR9344 /AX200NGW/ AP9342
With over 15 years of experience in wireless industry and penetrating market olfaction, Wallys has designed and manufactured many high quality and cost-effective routerboards and wireless network cards.
The above are our main chips and website information, if you are interested in our products, you can also directly contact our mailbox, we will provide you with the best service!
FYI, Wallys are able to provide customizable solutions based on your your Spec requirements for applications, feel free to let me know if any question
In the complex market, Wallys products stand out and are affirmed by partners. From 802.11 a - ax, Wallys always keeps up with the most cutting-edge wireless technology, aimed to help customers take the preemptive opportunities to occupy the market and lead a win -win cooperation.
BY:Wallys Communications (Suzhou ) Co., LTD
EMAIL:sales3@wallystech.com
1. DR600VX
QCA9880 802.11ac Dual band
QCA9880 2x2 2.4G/5G FCC/CE
https://www.wallystech.com/Network_Card/DR600VX-Qualcomm-Atheros-QCA9880-2T2R-MIMO-802.11ac-Mini-PCIe-Wi-Fi-Module-Dual-Band-2.4GHz-5GHz.html
https://www.youtube.com/watch?v=P6bf0KrO5e8
Qualcomm-Atheros QCA9880 chipset
2.4GHz max 24dBm & 5GHz max 23dBm output power
IEEE 802.11accompliant & backward compatible with 802.11a/b/g/n
2x2 MIMO Technology, up to 867Mbps
Mini PCI Express edge connector
Support the Frequency 4920MHz~4980MHz
RoHS compliance ensure a high level protection of human health and the environment from risks that can be posed by chemicals
Supports Spatial Multiplexing, Cyclic-Delay Diversity (CDD), Low-Density Parity Check
(LDPC) Codes, Maximal Ratio Combining (MRC), Space Time Block Code (STBC)
Supports IEEE 802.11d, e, h, i, k, r, v time stamp, and w standards
2. DR900VX
QCA9880 3x3 2.4G/5G FCC/CE/IC
https://www.wallystech.com/Network_Card/DR900VX-Qualcomm-Atheros-QCA9880-3T3R-MIMO-802.11ac-Mini-PCIe-Wi-Fi-Module-Dual-Band-2-4GHz-5GHz.html
https://www.youtube.com/watch?v=ixebAMco8sA
2.4GHz max 26dBm & 5GHz max 25dBm output power
IEEE 802.11ac compliant & backward compatible with 802.11a/b/g/n
3x3 MIMO Technology, up to 1.3Gbps
Supports Spatial Multiplexing, Cyclic-Delay Diversity (CDD), Low-Density Parity Check (LDPC) Codes, Maximal Ratio
FCC,CE and IC Certification
3. DR882
802.11AC 802.11AN wifi QCA9882
2x 2 5G High power Radio card
https://www.wallystech.com/Network_Card/DR882-Qualcomm-Atheros-QCA9882-2T2R-MIMO-802.11ac-Mini-PCIe-Wi-Fi-Module-5G-high-power.html
Featuring with industrial-grade Atheros’s QCA9882 chipset
Integrated with 2x 2 5G high power Radio Card
4.940GHz to 5.825GHz Frequency Range
2 x 5G MMCX Connectors
20MHz/40MHz/80MHz Bandwidth
Support 802. 11AC/AN
Wave-2 802.11ac Solution with MU-MIMO for Home Networks
The QCA9982 is a Wave-2 802.11ac radio that helps high-performance Wi-Fi routers, gateways, set-top boxes and range extenders to support more devices and more demanding applications in the connected home. The dual-band, 3x3 solution is designed to deliver peak data rates up to 1.3 Gbps, and uses Multi-User MIMO to maintain fast connections on increasingly crowded networks.
Dual-Band 3x3 MIMO 802.11ac/abgn WLAN SoC
The Qualcomm Atheros QCA9880 s a highly integrated wireless local area network (WLAN) system-on-chip (SoC) for 5 GHz 802.11ac or 2.4/5 GHz 802.11n WLAN applications. The QCA9880 integrates an on-board CPU for low-level setup of WLAN physical layer (PHY) and RF to offload the host processor for other tasks. It enables high-performance 3x3 MIMO with three spatial streams for wireless applications demanding the highest robust link quality and maximum throughput and range. The QCA9880 integrates a multi-protocol MAC, PHY, analog-to-digita...
Do you like our WiFi modules and want to test samples ? No problem ! Please contact us and provide your project description!
We supply wireless Wi-Fi data and 4G 5G LTE modules worldwide. There is no continent, where we would not have a satisfied customer! Yes, we have already supplied our Wi-Fi modules in Antarctica! You can find our modules, for example, in wind turbines, drones, ships, aircraft, both civil, acrobatic and military… on land, on water and in the air. NASA has also ordered samples, so the next goal is to get them into the outer Space!
签到总天数:62天
签到总奖励:1719金币
发表于 2022-11-4 00:53:24 | 显示全部楼层
谢谢
签到总天数:200天
签到总奖励:5781金币
发表于 2023-6-26 11:38:13 | 显示全部楼层
不错
GMT+8, 2025-11-6 02:54 , Processed in 0.131330 second(s), 14 queries , Gzip On, MemCached On.
