查看: 1277|回复: 0
[Nordic] 谷歌查找我的设备配件(Google Find My Device Accessory)详解和应用(8)
签到总天数:8天
签到总奖励:36金币
发表于 2025-8-13 09:12:45 | 显示全部楼层 |阅读模式
这些参数的配置宏的Kconfig文件位于nrf\subsys\dult\Kconfig
config DULT_MOTION_DETECTOR_SEPARATED_UT_SAMPLING_RATE1    int    default 10000    help      Sampling rate in milliseconds when motion detector is enabled in separated state.config DULT_MOTION_DETECTOR_SEPARATED_UT_SAMPLING_RATE2    int    default 500    help      Motion detector sampling rate in milliseconds when movement is detected in separated      state.config DULT_MOTION_DETECTOR_SEPARATED_UT_BACKOFF_PERIOD    int "Period in minutes to disable motion detector if accessory is in separated state" if DULT_MOTION_DETECTOR_TEST_MODE    default 2 if DULT_MOTION_DETECTOR_TEST_MODE    default 360config DULT_MOTION_DETECTOR_SEPARATED_UT_TIMEOUT_PERIOD_MIN    int "Minimum time span in minutes in separated state before enabling motion detector" if DULT_MOTION_DETECTOR_TEST_MODE    default 3 if DULT_MOTION_DETECTOR_TEST_MODE    default 480config DULT_MOTION_DETECTOR_SEPARATED_UT_TIMEOUT_PERIOD_MAX    int "Maximum time span in minutes in separated state before enabling motion detector" if DULT_MOTION_DETECTOR_TEST_MODE    default DULT_MOTION_DETECTOR_SEPARATED_UT_TIMEOUT_PERIOD_MIN if DULT_MOTION_DETECTOR_TEST_MODE    default 1440
motion detector模块对应的代码位于nrf\subsys\dult\motion_detector.c
总结
Nordic平台提供的代码实现了FMDN和DULT协议所必要的功能。另外,我们的Bluetooth LE协议栈稳定可靠,资源丰富,使用简单。如果客户还需要添加一些别的Bluetooth LE功能,得益于Nordic平台Bluetooth LE服务的模块化设计,用户自己能很方便的添加自己的或标准的Bluetooth LE服务模块。此外,我们在多链接和多广播集方面也表现优秀,很适合复杂Bluetooth LE设备的开发。
GMT+8, 2026-11-3 13:31 , Processed in 0.026631 second(s), 8 queries , Gzip On, Redis On.
