查看: 2275|回复: 1
[硬件设计(EDA)] Wallys/DR7915-wifi6-MT7915-MT7975-2T2R-support-OpenWRT-802.11AX-supporting-Mi...
签到总天数:8天
签到总奖励:36金币
发表于 2022-10-25 17:38:20 | 显示全部楼层 |阅读模式
Wallys/DR7915-wifi6-MT7915-MT7975-2T2R-support-OpenWRT-802.11AX-supporting-MiniPCIe-Module//QCA9882/QCA9880
Wallys could help clients build Prototype. We have a professional technical team supporting. Helping you realize your idea is our aspiration. Everything on RF is our enthusiasm. Different chipsets, different materials, different features, different designs...we could realize all you want. Making your idea visible and alive is what we persuit
We work exclusively with certified labs and also perform testing in-house, covering a wide range of certifications and standard, including FCC,CE and etc. Our lab testing solution provides exhaustive due diligence to limit your companys risk for liability and ensure that product meet all legal and safety requirement
OEM Since its inception in 2010, Wallys has had a strong team, including dozens of research and development personnel, a complete set of assembly lines, they play an irreplaceable role.Under the premise of ensuring the product quality, we will deliver the goods at the fastest speed and maximize the product benefit. ODM China has a complete wireless communication industry group, which enables ODM manufacturers to obtain the supply of low-cost components. Years of reform and opening-up have made China an ideal low-cost manufacturing base. Compared with the rapid development of the market, ODM services which focus more on design capability and production experience become more competitive
MT7915/MT7975/IPQ6000/IPQ6018/IPQ6010
BY:Wallys Communications (Suzhou ) Co., LTD
EMAIL:sales3@wallystech.com
DR7915
https://www.wallystech.com/Network_Card/DR7915-wifi6-MT7915-MT7975-2T2R-support-OpenWRT-802.11AX-supporting-MiniPCIe-Module.html
https://www.youtube.com/watch?v=yUoTXPFjNmk
MT7915+MT7975 Chipset
2.4GHz max 23dBm & 5GHz max 20dBm output power
IEEE 802.11ac / ax compliant & backward compatible with 802.11ax/ac/a/b/g/n
2×2 2.4G & 2×2 5G  MIMO Technology, up to 1.8Gbps Mini PCI Express edge connector
SupporttheFrequency2412MHz~2482MHz
SupporttheFrequency5180MHz~5825MHz
RoHS compliance ensure a high level protection of human health and the environment from risks that can be posed by chemicals
Supports Spatial Multiplexing,Cyclic-Delay Diversity (CDD), Low-Density Parity Check  (LDPC) Codes,Maximal Ratio Combining (MRC), Space Time Block Code (STBC)
Supports IEEE 802.11d, e, h, i, k, r, v time stamp, and w standards
CardsareindividuallycalibratedforQualityAssurance
Product Description
DR 7915 based on MT7915 + MT7975 Chipset is an enterprise wireless module integrated with 2x2 2.4G high power Radio module and 2x2 5G high power Radio module designed
specifically to provide users with mobile access to high-bandwidth video streaming, voice, and data transmission for office and challenging RF environment infactories, warehousese stablishment.
Specifications
DR882
802.11AC 802.11AN wifi QCA9882
2x 2 5G High power Radio card
https://www.wallystech.com/Network_Card/DR882-Qualcomm-Atheros-QCA9882-2T2R-MIMO-802.11ac-Mini-PCIe-Wi-Fi-Module-5G-high-power.html
Featuring with industrial-grade Atheros’s QCA9882 chipset
Integrated with 2x 2 5G high power Radio Card
4.940GHz to 5.825GHz Frequency Range
2 x 5G MMCX Connectors
20MHz/40MHz/80MHz Bandwidth
Support 802. 11AC/AN
签到总天数:183天
签到总奖励:1003金币
发表于 2023-2-11 08:34:31 | 显示全部楼层
不错,很好的资料
GMT+8, 2025-6-4 04:56 , Processed in 0.251377 second(s), 13 queries , Gzip On, MemCached On.
