查看: 13285|回复: 2
[供应] Wallys|IPQ4029/IPQ4019|Industrial wireless AP -DR-AP40X9(OUTDOOR)
签到总天数:8天
签到总奖励:36金币
发表于 2023-2-21 09:13:45 | 显示全部楼层 |阅读模式
Description
DR-AP4029(Outdoor) is a 2x2 2.4G&5G high power Radio AP Router which including 1x DR40X9(IPQ4019/IPQ4029) Board;1 x Onmi Antenna; 1 x POE Adapter(24V^1A~48V^0.6A);1 x Enclosure.
Planar Antenna
■  2 x 5G Antenna
■  5G: 16dbi
DRA25 Antenna
ElectricalProperties :
Frequency Range:2.4~2.5&5.15~5.85GHz
Impedance:50Ω
VSWR:2.0 Max (≤2.0)
Gain(peak):6±0.5dBi
Polarization:Linear; Vertical
Physical Properties :
Cable:RG-141 Cable
Connector:N-type PLUG
Antenna CAP:ABS
OperatingTemp:-40℃~+65℃
Storage Temp:-40℃~+75℃
CableTemp:<+250℃
Enclosure
■  Dimension: 275x140x48mm
■  UV Protected and Durable ABS Radome
■  IP67 Waterproof Level
■  Support Wallys  DR4029
Symbol
Parameter
CPU
IPQ4029/IPQ4019(Quad core ARM Cortex A7 at 716.8 MHz)
Antenna Connector
2 x 5G MMCX connectors;2x2.4G MMCX
10/100/1000Mbps Gigabit Ethernet
2xRJ45
SFP connector
1xSFP fiber module connector (optional)
3G/4G connector
1xminipcie 3G/4G connector support with two sim card
USB connector
1xUSB 3.0 connector
POE
24V~48V passive POE
DC Jack
24V~48V power supply
ROHS Compliance
YES
Dimension
115mm x 105mm x 16mm
Max Power
48.1V x 0.180A= 8.658W
Nor Flash
2MB~32MB
Nand Flash
128MB
DDR
256MB~512MB
Wallys Communications (SuZhou) Co., Ltd., http://www.wallystech.com,which is mainly engaged in the research and development and production of wireless communication products,providing superior OEM/ODM/JDM services in wireless communications and customer-specific solution.In addition to the PCBA mainboard, we can also customize indoor or outdoor antennas, which we have extensive experience in. There is also the Tooling. We can do the Tooling for the customer, to undertake a variety of materials
mainly metal and plastic enclosure production. Whether antenna enclosure or router enclosure, we can customize for you. Besides of the Qualcomm chips we currently use, we can also use different chips to design according to customers' needs
MAIL:sales3@wallystech.com
签到总天数:221天
签到总奖励:2792金币
发表于 2023-2-24 09:12:49 | 显示全部楼层
签到总天数:221天
签到总奖励:2792金币
发表于 2023-2-24 09:13:11 | 显示全部楼层
好产品,谢谢分享
GMT+8, 2026-10-22 20:04 , Processed in 0.020934 second(s), 10 queries , Gzip On, Redis On.
